 Define Command Short Cuts Keeps forgetting settings
Sam Lemon's profile image
Sam Lemon posted 04-12-2023 07:39
I have defined several keyboard shortcuts to functions inside TBC.
Every time I boot up the software it forgets half of them, also I think the UI on the feature could do with an update having to export the list to excel each time to see what is free is a pain.
Does it automatically sync between different projects?
Many Thanks
Sam
ETHAN AMEZCUA's profile image
ETHAN AMEZCUA
This still appears to be an issue. I was seeing it happen only on updates, but now it's happening all the time.
I also wholeheartedly agree that the UI for defining the shortcuts is inadequate (attached is an image of a good UI, it's the QGIS interface which allows you to set the shortcuts by just Pressing the Keys, and allows you to save and load custom shortcuts).
Btw, I even tried creating and saving a "User Options" within the User Profile Manager. Reloading the named "User Option" did not restore the custom keyboard shortcuts I defined.
Attachment  View in library
image.png 47 KB
The command shortcuts are saved with the ribbon settings. Even if you don't change the ribbon layout it's worthwhile to save/export the settings in "customize ribbon".
But that one is super annoying as well. I'd like to be able to export just my tailored tabs instead of the whole ribbon layout. I've had issues before that I imported my ribbon from a previous version and the new commands they had introduced with the new TBC version had disappeared from the tabs and I had to manually add them back.
And if you see that there are third party, to pay for, macros available to mitigate the shortcut issue it's obvious that it is inconvenient to use.
But that is the issue, it's just inconvenient for us, it works and is not broken. So, Trimble won't bother to look into it and spend our maintenance fees, when there is already a solution available where we just have to pay extra money out of our pocket.
I haven't used QGIS a lot, but recently I had to use it quite a few times to clip datasets (bathymetry, enviro vegetation boundaries ...) from government sites since TBC literally sh** itself importing/handling those. And I was really impressed about the performance of it. A several hundred MB linework file was on the screen in seconds. And clipping hundreds of very long bathymetry lines with a rectangle was done in seconds as well. I was already getting of my chair to get me a coffee since I had tried the same in TBC before and it basically crashed.
Just had to use it yesterday again when TBC crapped itself importing a 3.2 MB KML file with long polylines/hatches (there seems to be a serious problem in hatch handling in TBC). CPU usage spiking, fans rushing, but nothing happening for >10 minutes. QGIS, file on the screen in a second.
And being able to set each layers coordinate system and the view itself to yet another one is pretty impressive as well. QGIS that is, not TBC.
ETHAN AMEZCUA
With the exception of some potential problems with the "ribbon layout" that Ronny brought up (that I don't totally grasp), Ronny's suggestion appears to be a workaround for the OP's issue of TBC forgetting the User Defined Shortcuts - here's how that worked for me:
  • defined all the desired keyboard shortcuts
  • signed into the Trimble ID in the TBC session (little blue person top-right corner of window)
  • opened the "User Profile Manager" on the Support Ribbon
  • toggled the "Ribbon" heading in the "User Profile Manager" and selected "Save Current" - name it something reasonable
  • anytime TBC forgets your definitions, open the "User Profile Manager" again,  toggle the "Ribbon" heading and hit "OK", then select "Yes" to the question of restoring options.
Very cool that once you get the shortcuts defined, you can hover over the tiles and a pop-up will remind you of your shortcut setting.
