I have my own aerial imagery in my TBC project; however, it does not cover all of the area that I need - think corridor mapping. I would like to use the DigitalGlobe Imagery layer as supplement to my own imagery but when you turn on the base map in TBC it covers my imagery; even when mine is set to priority '1' in the settings.
Is there a way to drop the default TBC imagery to the back? This is something you can do in ESRI ArcMap Pro, and I find it very useful there. If I have missed a setting that would be fantastic, but I fear I have not.
#imagery #TBC #DigitalGlobe Imagery
Use the " Image Capture" function. It will create a snapshot of whatever is on the screen. Be sure to turn off linework and anything else you do not want. Then go to the Snapshots folder inside the project's support folder and drag the image in.
small setting to give a try is the transparency. Its in the properties in Project Explorer
