 DiNi .dat file not opening in TBC
Mathew Daffern's profile image
Mathew Daffern posted 11-13-2023 09:28
I am trying to run dual line levels with the DiNi .3mm and have error codes stating that the run number chenged unexpectedly, also warnings on all shots that the measurement was not imported because it is not in a run.  Any help would be appreciated, for importing the file, and for information on actually running dual lines in the field (BBFF or Cholesky method).  Thanks
