That's another TBC bug as it looks like.
Check the text style you're using. If you're using sheet units and set it below 4 mm or so, it won't work. I assume some rounding is kicking in.
Text style at 4 mm sheet units works
text style set to 3 mm at sheet units doesn't
It does work if you don't rotate the labels
Now the text style set to ground units at 0.002
Every day we raise again to the challenge that is using Trimble products.
