I am attempting to import a jxl file into an existing TBC project and get an error message about an unexpected error.
The error replicates in a blank TBC session.
I'm not sure how to interpret what I'm seeing in the error window:
Exception Count: 1
Exception Source: Trimble.Vce.Data.JobXML
Exception Type: System.NullReferenceException
Exception Message: Object reference not set to an instance of an object.
Exception Target Site: 옄
---- Stack Trace ----
.큉.옄(ProgressForm A_0)
Trimble.Vce.UI.Client.DLL : N 00215
.큉.RunWithProgressBar(ProgressBarProcessFunction function, Boolean canBeCanceled)
Trimble.Vce.UI.Client.DLL : N 00135
Trimble.Vce.Data.Import.ImportEngine.阷(IImportInfo A_0, List`1 A_1)
Trimble.Vce.Data.Import.DLL : N 02352
Trimble.Vce.Data.Import.ImportEngine.ImportFiles(IImportInfo[] importInfos)
Trimble.Vce.Data.Import.DLL : N 05363
Trimble.Vce.UI.BaseCommands.ImportService.ImportCmdFiles(IImportInfo[] infos, Boolean useCmdMarkers, Boolean showReportAfterwards, Boolean zoomExtentsAfterwards)
Trimble.Vce.UI.BaseCommands.DLL : N 06545
Trimble.Vce.UI.BaseCommands.ImportService.ImportFiles(IImportFilesServiceItem[] files)
Trimble.Vce.UI.BaseCommands.DLL : N 00210
Trimble.Vce.UI.ViewWindowBase.옄(Object A_0, DragEventArgs A_1)
Trimble.Vce.UI.Client.DLL : N 02042
---- Stack trace from the original exception which stopped progressBar----
Trimble.Vce.Data.JobXML.Nodes.StartRoundNode.Process(ProcessingContext context)
Trimble.Vce.Data.JobXML.DLL : N 00028
Trimble.Vce.Data.JobXML.ProcessingContext.ProcessRecord(XPathNavigator nav)
Trimble.Vce.Data.JobXML.DLL : N 00635
Trimble.Vce.Data.JobXML.DataReader.茁(XPathNavigator A_0, RawDataProcessorContext A_1, List`1 A_2, IList`1 A_3, ImportInformation A_4)
Trimble.Vce.Data.JobXML.DLL : N 02566
Trimble.Vce.Data.JobXML.DataReader.Read(ImportInformation importInformation, List`1 readFilter, IList`1 pointPairs)
Trimble.Vce.Data.JobXML.DLL : N 00552
Trimble.Vce.Data.JobXML.FileReader.茁(List`1 A_0)
Trimble.Vce.Data.JobXML.DLL : N 02678
Trimble.Vce.Data.JobXML.FileReader.Read()
Trimble.Vce.Data.JobXML.DLL : N 00011
Trimble.Vce.Data.JobXML.Importer.Import(String fileName, IProject iProject, ImportInformation importInformation, ICoordinateSystemUI iImportDlgs, Boolean& needRecomputeProject, Boolean ShouldAddFilenameToImportInformation)
Trimble.Vce.Data.JobXML.DLL : N 00258
Trimble.Vce.Data.JobXML.Importer.Import(String fileName, IProject iProject, ImportInformation importInformation, ICoordinateSystemUI iImportDlgs, Boolean& needRecomputeProject)
Trimble.Vce.Data.JobXML.DLL : N 00037
Trimble.Vce.Data.Import.ImportEngine.阷(IProgressBarControl A_0)
Trimble.Vce.Data.Import.DLL : N 00290
Trimble.Vce.UI.쟢.죑()
Trimble.Vce.UI.Client.DLL : N 00609
