 Export Corridor as RXL
Steven Grosch's profile image
Steven Grosch posted 05-17-2024 05:41
I created a corridor using TBC v. 2023.11.  In creating the template, for side slopes, I used slope by depth tables.  The export failed with an error message that stated that export is not possible if tables are used.  We have an advanced survey license.  The export works fine with the side slopes change to slope ratio.  Can anyone point me in the direction of a solution?  Thank you.
Francisco Guerrero's profile image
Francisco Guerrero
Is the Side Slope the actual command or a instruction in the Corridor command?   if, its the Side Slope command just create a corridor with the linestring as reference from the SS command.
Or, if its the corridor command you will need to explode the surface into breaklines and then create a new corridor with those linestrings as references lines.  Would a DTM or XML be a better fit??
Nelson Hays's profile image
Nelson Hays
I use tables in corridors all the time, and they work just fine when exported as a .VCL, .PRO, .SVD, .TTM, .XML
