We frequently have issues like this with ORD alignments. ORD supports gaps (and overlaps) in alignments, so situations like this are not seen as problems through the eyes of ORD.
A quick way to find this in ORD is to run the Horizontal Report on the alignment, and in the Report Browser choose the "HorizontalAlignmentCheckIntegrity" report. Look at the "Northing Difference (End to Next)" and the "Easting Difference (End to Next)" columns, if any numbers are not zero there's the gap/overlap.
Ideally this should be fixed in ORD, as removing the gap/overlap will change the stationing of the alignment (and objects referenced from the alignment) as seen in ORD. Changing it outside of ORD will result in discrepancies between e.g. TBC and ORD. If it's truly desired to maintain a gap in the alignment, it will need to be broken into separate alignments to maintain correct stationing.
