Question Thread View
Community Navigator
18.1K
1.3K
2.9K
Back to {0}
Issue Publishing Field Data to Project Library
Add a tag
x
Wellerson Souza
posted 10-13-2022 13:06
Hi
Very often when I am publishing a new design from selectable 3d lineworks to project library I came across with this error.
"The Following items failed to publish:
Teste 3D: The following line has a segment whose planimetric length is less than the minimum allowed, but whose 3D length is greater than the minimum so it cannot be automatically
removed."
See attached for more information.
Then I have to go through each line error and remove it from the design created. Its such a hard work to fix this issue when we have many lines to be removed. Is there any way to fix this problem?
Thanks
Wellz
View in library
93 KB
Marian Plucinski
posted 10-13-2022 14:41
Easy-peasy.
I assume you're suffering from lines which are vertical. Almost zero 2D length. Like the one below:
Solution:
Select all your linework
Data Prep -> Project Cleanup
Object to process -> Current Selection
Remove zero length lines
