 Leap second - time missing in base line processing
Marc Braipson's profile image
Marc Braipson posted 07-21-2023 09:10
Hi Evryone,
How could I get rid of the message "leap second" in session editor?
Thanks in advance for your help...
Marc Braipson
Topo Mission Chief - Nachtigal Hydro-Power Project - Cameroun
Albert Olivier's profile image
Albert Olivier
Hi Marc
Which TBC GNSS receivers did you use to capture the static data with? Please will you send me the T02 files and will have look at if for you. Which version of TBC are you using? Thanks
Albert
Marc Braipson
Hello Albert,
Thanking you for your reply.
See, we are using R2 (2x) and R8 (2x) receivers.
The TBC version we use is 5.70
Prior 14 July, there not such a error message - with leap second missing.
Sorry for my late reply, as my wife gave birth to a baby kid on late 29 July, and so I was off for a week;
Here are a sample of T02 files with this error messages
Is there any consequence in "position accuracy" deterioration due to this message?
See, we have to monitor a damp with an accuracy of 3,5 mm.
We do monitoring sessions every week.
Part of these equipement was puchased in Brussels recently and for the purpose of this monitoring (R2 receivers) , part (R8) are old receivers that turn in the company - and I can't tell where they were baught.
Marc Braipson
Topographic Mission Chief
Nachtigal - Cameroon
Tel : +237650893731
E-mail: mbraipson@ccn-btp.com
Albert Olivier
Hi Marc
In the Support tab in TBC, click on "Check for Updates". Update everything expect the TBC version 5.90 upgrade, try to import the T02 files again and see if that solves the problem. Please email your T02 file to me, albert_olivier@trimble.com. I will try in TBC 5.90 to process and check the files.
