 Leapfrog / Seequent Data Exports
John Mill's profile image
John Mill posted 09-26-2024 15:22
Does anybody have any suggestions / tips for Data Export from Leapfrog (Bentley Geotechincal modelling) into Surfaces in TBC?
Job is a 12km Motorway for which I need to start doing some Mass Haul analysis - and the Geotech will be revised in 6 months so I'll need to repeat the whole process
Currently 10 distinct Material layers of varying location and depths
I've tried asking for DGN and 3d DXF exports but
  • DGN only seems to import as a 3dShell into TBC - I can then Explode them using RPS Explode solids for a couple of the files but  a 17mb file just "hangs" for 2 hours
  • 3d DXF is just too big a file 220 mb for one surface - and the triangles join across regions
John Mill
I've worked out a solution,
Using 3d DXF from LeapFrog for each surface
I've imported that into GlobalMapper (it handles large datasets a lot quicker)
Then right clicked that data set (Layer) and
Layer - EXPORT
Selected LandXML format
Imported into TBC - it respects Regions and creates surface (there are some Surface error flags but I'm ignoring those)
