 LiDAR QC with TBC (MX50)
Jules Suzineau's profile image
Jules Suzineau posted 10-14-2025 12:14
Hello TBC Community!
I'm currently using the new LiDAR QC tool available for mobile mapping processing. However, I can't process any missions longer than 3 hours. Regardless of the mission's content, if it exceeds 3 hours, I get a MATLAB error. We have two MX50s.
Obviously, the new directive is that missions must be less than 3 hours, but I'm still in a tough spot with my old missions, which can be up to 5 hours and 30 minutes long.
Is anyone else using LiDAR QC? I see very few posts, no video support or anything else. I could really use your help! What should I do?
Skyler Neumeyer's profile image
Skyler Neumeyer
Hi Jules,
Already working on a fix for this and will try to remember to loop you in once the fix is testable.
There's a couple of workarounds that might be useful to you in the meantime though. As you've already found, it's related to input sbet duration, and not necessarily what scan data is included so if you can reduce the duration of the input sbet it can bypass the error. It all depends on the layout and specifics of your project though. Lets say you have a 5 hour collection, but it's two suburban areas with a single road connecting between them. You can process the first half of the project and all of those runs, then the second half of the project and all of those runs and each will be aligned and contain the benefits of LidarQC, but then traditional registration would need to be used in the areas where the two sections overlap. In this hypothetical scenerio, it could be just the one road connecting the two suburbs that would need Run to Run registration on it.
