Hi everyone
Is it possible to process a single PPK trajectory from multiple base stations in TBC?
In other words, instead of creating an individual trajectory from each base station, one trajectory would be created using data from a network of bases. Is this even possible with the PPK method?
Previously, I've just compared the multiple trajectories and picked one to use.
The purpose would be for a moving rover, like a drone, moving through a network. Or if you wanted multiple bases to contribute to the one final PPK solution to improve the result.
Cheers
Bevan
