I'm having a new issue with TBC 5.81. I recently downloaded a .LAS file from NOAA and when dropping into TBC project, the cloud is in the wrong coordinate system and is scaled verry small. I've had success multiple times in the past with no issues. My TBC Project is in the correct coordinate system and I know the coordinate system of the LAS file. Am i doing something wrong or is my data corrupt? I re-downloaded the data multiple times? Attached is the data description, I am unable to upload the LAS file to this thread as it says it is an unsupported file.
Thank you.
James
Request:
Projection: NAD83(NSRS2007) / Massachusetts Mainland (ftUS); Format: Points - LAS; Lat,lon bounding box: 42.05883627,-71.47353172 42.06651474,-71.46275997; Vertical Datum: NAVD88 height (ftUS); Vertical Units: feet; Horizontal Datum: NAD83; Horizontal Units: US survey feet; Classes used: Ground;
Processing Notes: Data is really in NAD83(2011) but tagged files with NAD83(NSRS2007) for greater software compatibility.
