 Orthomosaic image fail
James Skiles's profile image
James Skiles posted 01-14-2025 09:26
I have been trying to process a flight for a orthomosaic. it says out of 1163 photos 740 failed. I continued with the processing. and everything finished. when I created the deliverables and imported my ortho half the flight is not there. I have not been able to find a solution for this. it has happened for others in my office on other flights as well. How do I fix this. I don't know what is wrong. I have attached the project.
ian bissonnette's profile image
ian bissonnette
this is likely hard to answer and mostly have experience processing photogrammetry in other software, but from that i would first question the flight parameters. do you have enough overlap? i have found that flying too low to the ground when there are lots of trees or other vertical projections can make the processing difficult. likely because of the distortion when you pass over the trees and you “see” a lot of the side of the tree. if you are higher then a larger percentage of the photo is looking at the tops of the trees and the software can then find more common points to stitch together. further to this, if there is lots of wind, then the movement of the trees can make it even worse because the common points are now not in common.
because the initial photos are failing it leads me down this direction. no way it will solve the ortho without using the majority of the photos. others might have more ideas about any settings in tbc that might help.
