Upgraded to TBC 2024 last year and ever since then I cannot classify any Point Clouds. I select the classify point cloud command, then select the point cloud region, after pressing classify to start it, it starts to run for about 20 seconds then the entire program crashes. I have tried point clouds from previous projects that have classified before in older TBC versions and same behavior, I've tried uninstalling/reinstalling the entire program and still the same issue. I've also tried updating to 2024.10 with same exact results. I've tried uninstalling and installing previous versions and the issue seems to follow. Before updating to 2024.00 I had no issues classifying any point clouds. No matter what I try, the program crashes every single time without fail. I'm at a loss for what to do at this point.
PC specs: cpu i9-13900K, memory 128GB, 2tB ssd (with plenty of available space), NVIDIA GeForce RTX 4080, Windows 10 Pro
