Hi Mauro and Brandon,
I will share my limited testing on this. I too have been able to postprocess the trajectory from the DJI with the GNSS module. When you import the data, there is an almost “hidden” Settings button at the bottom. Change Force Kinematic to Yes. Import the OBS file. Now you can process it to your base just like any other post-processed kinematic data.
I did this out of curiosity, but it didn’t serve any useful purpose in my case. The trajectory calculates a point every epoch, be it 1 second or 1/5 second, whatever your base is collecting. However, the photos are taken at times based on the drone software, and do not coincide with the GNSS epochs. My guess is that the Photogrammetry package uses the timestamps in the MRK file to interpolate the photo locations along that trajectory. I didn't proceed to try to export those trajectory points, but I assume there is a way.
I experimented with Emlid Studio, but I found the process way too clunky when it came to antenna heights, coordinate systems, and the fact that I had to convert my base data to RINEX.
