 Recovering Scan Data for SX12
Randall Bonnell's profile image
Randall Bonnell posted 02-27-2025 16:53
Hi there,
I'm working with an SX12 to collect repeated scans over an alpine area. All except one of my recent jobs load into TBC just fine. I've done as much trouble shooting as I know how at this point and I've consulted a dozen or so community threads here for help. I figured I'd open a new thread in the hopes that this issue has been observed/resolved by someone else!
The issue:
When I import either the .job or .jxl file into TBC, the control points load and a station file populates under the imported files header, but not under the Scan Stations header and no scan data is visible.
I can import the .rwcx file and it will populate under the scan stations header and show the scan data. However, there is only one station property --> "Name" and the scan does not appear to be tied to the .job file.
I've checked Trimble Access --> under review job, it says "Tilt error - Yes" and "Deleted - Yes". I suspect that this is the root cause of my issue.
Questions:
  1. Is there a way to tie a .rwcx file to station data and control points?
  2. Can I undo the "Deleted" on the job file in Trimble access?
  3. Are there any other routes that can be taken?
Thank you so much for your help!
Sincerely,
A radar guy dabbling in lidar...
