 Removing the displacement model for local New Zealand projections
Serg Chirila's profile image
Serg Chirila posted 05-22-2023 21:29
Hi all,
Is there a way of removing the displacement model when using local projections from New Zealand? I am using Trimble v5.80.
The displacement model seems to always be added when choosing projections from New Zealand. Can a custom coordinate system be created where no displacement is included? If so, how?
Many thanks,
Daniel Muir's profile image
Daniel Muir
Hi Serg,
You can simply delete the file C:\ProgramData\Trimble\GeoData\nzgd2000_deformation_model_20180701.xml file
If you are looking to recreate an older computation in the past you can remove the <Component> 's from the XML for the newer reverse patches.
https://www.linz.govt.nz/guidance/geodetic-system/coordinate-systems-used-new-zealand/geodetic-datums/new-zealand-geodetic-datum-2000-nzgd2000/nzgd2000-deformation-model
Daniel.
