 Review Job - TBC
Jump to  Best Answer
Brandon King's profile image
Brandon King posted 04-11-2023 05:15
Is there a way to review job in TBC? For example, on the data collector within Trimble Access, you can review job which will also show you items such as computing the inverse between points. Is there a way to view that same exact thing in TBC? Ultimately I am trying to find a way in TBC to view what points a crew might have inversed between. Thanks!
Brandon King  Best Answer
Solved: Running the survey report.xsl
