 TBC 5.10.1 very slow File Menu
John Hughes's profile image
John Hughes posted 03-28-2025 08:29
One of our users on TBC 5.10.1 is having issues every time he clicks on the file menu it takes fully 45-60 seconds before it appears.  I realize he is on an older version but he is reluctant to upgrade at this time and I was hoping someone here might have a simple solution.
Thx!
David Olander's profile image
David Olander
As you said, the real solution is to upgrade, as that problem was resolved.
If it is the problem I am thinking of, TBC seemed to be opening and indexing each file in the folder it was using, which was taking a long time in many instances. If that is the problem you are facing, the work-around that I had was to have a folder on my desktop called TBC Import. I would put stuff there and then use that folder for TBC to index, import the file(s), then clear that folder when done.
