It would seem that either the latest ArcGIS Pro (3.4) or latest TBC/Access broke the attachment (photos) piece of the GIS module workflow. It seems to be a pathing issue where the GIS module simply cannot access the attachments via the ArcGISProProvider3 connection type (whether File Geodatabase or ESRI Feature service). The photos are associated with the point features (and line features) in Trimble Access and ends up TBC just fine and can be previewed. It’s just not making its way into the File Geodatabase (or Feature Service). I have tried this by selecting both the media feature and point and just the point and it results in the same outcome upon writing features to GIS. Can someone at Trimble confirm that they are seeing this as well? Also, assuming that is confirmed, when would we expect a fix? I'd prefer not to roll back ArcGIS Pro or TBC or Access (Depending on the culprit)!
@Matthew Morris
@Dejan Mitrovic
@Shane Lyons
FYI...Trimble has confirmed that this is a known issue and they are working to resolve it.
