All,
I would like some help if you would. I just got a new PC and the thing is a beast to say the least. I went ultra high end on Intel processor, motherboards, drives and GPU. I use a lot of point clouds and aerial images and that it works great once the images or clouds load I can navigate with no lag or buffering. However, I noticed that when running simple commands like create linestring or join there is and catch or lag in the screen which really mess with your mouse flow. Even clicking on a surface of IFC to create the linestrings creates at least a 1sec lag for each click and about 3sec lag when you open the line string command and hit the enter to start the command. Now I run a Alienware 38in wide screen with G-Sync and 144 refresh rate and another samsung 32in 1080 display. It would seem the lag in the commands are worse on the nicer alienware then the samsung. This is highly disappointing as you can imagine but I am hoping there is a setting that can solve this. There are so many setting in the NVIDA settings and I am wondering if I got something in there that needs turned off or on. Oh, and yes I keep my drivers up to date just so you know. So any ideas would be helpful at this point.
Thanks,
