All,
Since running 5.81 I have noticed that every once in a while TBC will wipe all the elevations from my points. Most recently I imported and csv file with control points for a highway job. I have built the models and I exported my data out through the new WM flow and when I got t the field I had no elevations on any of my control points. I went back into TBC and sure enough all the points had the elevations deleted but everything else from the point was intact. The site is not calibrated and I imported the points as grid only points that can't be moved or elevated. So why did TBC wipe the elevations? Is this a bug?
Ben
