 "Thick" lines, not a result of sizing
Robert Stallings's profile image
Robert Stallings posted 08-22-2022 11:45
When I am working in a project, sometimes I click on a  line and it will cause certain [entire} layers to thicken up and change.  This can be resolved by saving, closing and reopening.  There is no trigger that I can put my finger on: large files/small files, color, layer name, number of times per day, etc.  Has anyone else experienced this?
Thanks,
Robert
Charlie Sorg's profile image
Charlie Sorg
Yes, unfortunately, this is an ongoing issue that due to the problem of not being able to easily reproduce the issue, it is a work in progress.
Francisco Guerrero's profile image
Francisco Guerrero
A lot of people have.  So, without closing and reopening your project.  Go to HOME>click Plan View.  This will open a new plan view window restoring the graphics.
Anonymous User's profile image
Anonymous User
I had the same problem several times. Most of the time this error occurred as soon as I imported a DXF or similar. The line widths of different layers were set to undefined (not to ZERO). As soon as I adjusted the line width, everything worked again.
BR from Germany
Marcus
