 Trimble.Vce.Coordinates.CoordinateSystemDefinition.OutOfBoundsException
William Asselin's profile image
William Asselin posted 10-22-2024 10:46
Hi!
I try to export my panorama to google earth via the export tab and this error always raise for this project. I try with another projet and it work. I try to start a new projet with this data and the error always come... I never found an answer for this problem but I hope to be lucky today.
Exception Count:       7
Exception Source:      Trimble.Sdk.Coordinates
Exception Type:        Trimble.Vce.Coordinates.CoordinateSystemDefinition.OutOfBoundsException
Exception Message:     Échec de la transformation des coordonnées. La cause probable est que le géoïde est hors limites.
Exception Target Site: 䵌
---- Stack Trace ----
    .伥.䵌(ProgressForm A_0)
    Trimble.Vce.UI.Client.DLL : N 00213
    .伥.RunWithProgressBar(ProgressBarProcessFunction function, Boolean canBeCanceled)
    Trimble.Vce.UI.Client.DLL : N 00136
    Trimble.Vce.UI.BaseCommands.ExportCmdUI.OK_Click(Object sender, EventArgs e)
    Trimble.Vce.UI.BaseCommands.DLL : N 00253
    System.Windows.Forms.Control.OnClick(EventArgs e)
    System.Windows.Forms.dll : N 00135
    System.Windows.Forms.Button.WndProc(Message& m)
    System.Windows.Forms.dll : N 13001007
    System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    System.Windows.Forms.dll : N 00194
---- Stack trace from the original exception which stopped progressBar----
    Trimble.Vce.Coordinates.CoordinateSystemDefinition.TNZCoordTransformer.TNZTransformer(CoordinateTypes fromType, Double[] from, CoordinateTypes toType, Double& toX, Double& toY, Double& toZ)
    Trimble.Sdk.Coordinates.DLL : N 02318
    Trimble.Vce.Coordinates.CoordinateSystemDefinition.TNZCoordTransformer.ꟽ(CoordType A_0, Double[] A_1, CoordType A_2, Double& A_3, Double& A_4, Double& A_5)
    Trimble.Sdk.Coordinates.DLL : N 00962
    Trimble.Vce.Coordinates.CoordinateSystemDefinition.TNZCoordTransformer.ꟽ(ICoordinate A_0, CoordType A_1, TransitionDetails& A_2)
    Trimble.Sdk.Coordinates.DLL : N 02045
    Trimble.Vce.Coordinates.CoordinateSystemDefinition.TNZCoordTransformer.Transform(ICoordinate inCoord, CoordType outType, TransitionDetails& info)
    Trimble.Sdk.Coordinates.DLL : N 00609
    Trimble.Vce.Coordinates.CoordinateSystemDefinition.TNZCoordTransformer.Transform(ICoordinate inCoord, CoordType outType)
    Trimble.Sdk.Coordinates.DLL : N 00029
    Trimble.Vce.Coordinates.CoordinateStringBuilder.ConvertPoint(Point3D pointNEH, Point3D& pointLLH)
    Trimble.Sdk.Coordinates.DLL : N 00435
    .뿌.릊(IProject A_0, Point3D A_1)
    Trimble.Vce.Data.Kml.DLL : N 00177
    .뿌..ctor(Project A_0, RDImageStation A_1, String A_2, Boolean A_3, IDataUploader A_4)
    Trimble.Vce.Data.Kml.DLL : N 00861
    Trimble.Vce.Data.Kml.KmlExporter.Export(IProject iProject, IExportInputData inputData, String FileName)
    Trimble.Vce.Data.Kml.DLL : N 01898
    Trimble.Vce.UI.BaseCommands.ExportCmd.DoExport(IProgressBarControl progressBarControl)
    Trimble.Vce.UI.BaseCommands.DLL : N 04337
    Trimble.Vce.UI.BaseCommands.ExportCmdUI.DoExport(IProgressBarControl progressBarControl)
    Trimble.Vce.UI.BaseCommands.DLL : N 00223
    Trimble.Vce.UI.䶢.䷍()
    Trimble.Vce.UI.Client.DLL : N 00612
Date and Time:      2024-10-22 13:39:37
Machine Name:       PC-GIS
IP Address:         fe80::1ae6:2a97:b966:f406%12, 192.168.10.68,
Current User:       TOPOCOM\wasselin
Application Domain: TrimbleBusinessCenter.exe
Thread Name:        Office UI Thread
---- Assemblies in AppDomain ----
Assembly Full Name:  mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Assembly Full Name:  TrimbleBusinessCenter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/TrimbleBusinessCenter.exe
Assembly Full Name:  Trimble.Vce.UI.Controls, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Controls.DLL
Assembly Full Name:  System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
Assembly Full Name:  System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Assembly Full Name:  System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Assembly Full Name:  Trimble.Vce.UI.UIManager, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.UIManager.DLL
Assembly Full Name:  Trimble.Sdk.Interfaces, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Interfaces.DLL
Assembly Full Name:  netstandard, Version=2.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/netstandard/v4.0_2.0.0.0__cc7b13ffcd2ddd51/netstandard.dll
Assembly Full Name:  Trimble.Sdk.DiskIO, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.DiskIO.DLL
Assembly Full Name:  Microsoft.Extensions.Configuration.Abstractions, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Configuration.Abstractions.DLL
Assembly Full Name:  Trimble.Vce.UI.Client, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Client.DLL
Assembly Full Name:  System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Assembly Full Name:  System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Assembly Full Name:  System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Assembly Full Name:  Microsoft.Extensions.Configuration.FileExtensions, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Configuration.FileExtensions.DLL
Assembly Full Name:  Microsoft.Extensions.Configuration.Json, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Configuration.Json.DLL
Assembly Full Name:  Microsoft.Extensions.Configuration, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Configuration.DLL
Assembly Full Name:  Microsoft.Extensions.FileProviders.Abstractions, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.FileProviders.Abstractions.DLL
Assembly Full Name:  Microsoft.Extensions.FileProviders.Physical, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.FileProviders.Physical.DLL
Assembly Full Name:  Microsoft.Extensions.Primitives, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Primitives.DLL
Assembly Full Name:  System.Memory, Version=4.0.1.2, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/System.Memory.DLL
Assembly Full Name:  System.Runtime.CompilerServices.Unsafe, Version=6.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/System.Runtime.CompilerServices.Unsafe.DLL
Assembly Full Name:  System.Text.Json, Version=7.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/System.Text.Json.DLL
Assembly Full Name:  System.ValueTuple, Version=4.0.3.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/System.ValueTuple.DLL
Assembly Full Name:  System.Buffers, Version=4.0.3.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/System.Buffers.DLL
Assembly Full Name:  System.Numerics.Vectors, Version=4.1.4.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/System.Numerics.Vectors.DLL
Assembly Full Name:  System.Runtime.InteropServices.RuntimeInformation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.InteropServices.RuntimeInformation/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.InteropServices.RuntimeInformation.dll
Assembly Full Name:  Trimble.Vce.UI.BaseCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.BaseCommands.DLL
Assembly Full Name:  Infragistics4.Win.UltraWinDock.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinDock.v22.2.DLL
Assembly Full Name:  Trimble.Vce.Data.DWG, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.DWG.DLL
Assembly Full Name:  TD_SwigCoreMgd, Version=23.9.0.0, Culture=neutral, PublicKeyToken=8e28356228e490a2
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/TD_SwigCoreMgd.DLL
Assembly Full Name:  TD_SwigDbMgd, Version=23.9.0.0, Culture=neutral, PublicKeyToken=5ccc28765cdf0a88
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/TD_SwigDbMgd.DLL
Assembly Full Name:  Trimble.Vce.Data.SDE, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SDE.DLL
Assembly Full Name:  Trimble.Vce.Data.Kml, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Kml.DLL
Assembly Full Name:  Trimble.Sdk.Properties, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Properties.DLL
Assembly Full Name:  Trimble.Sdk, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.DLL
Assembly Full Name:  Trimble.Sdk.UI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.UI.DLL
Assembly Full Name:  Infragistics4.Win.UltraWinToolbars.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinToolbars.v22.2.DLL
Assembly Full Name:  System.Reactive, Version=5.0.0.0, Culture=neutral, PublicKeyToken=94bc3704cddfc263
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/System.Reactive.DLL
Assembly Full Name:  TrimbleBusinessCenter.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/TrimbleBusinessCenter.resources.DLL
Assembly Full Name:  Trimble.Vce.Services.Auth, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Auth.DLL
Assembly Full Name:  Trimble.Vce.TbcLicense, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.TbcLicense.DLL
Assembly Full Name:  Newtonsoft.Json, Version=13.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Newtonsoft.Json.DLL
Assembly Full Name:  Trimble.Trdm.ServiceManagement, Version=2.20.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Trdm.ServiceManagement.DLL
Assembly Full Name:  Loupe.Agent.NETCore, Version=4.13.0.0, Culture=neutral, PublicKeyToken=ca42a1ee8d2e42d3
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Loupe.Agent.NETCore.DLL
Assembly Full Name:  Loupe.Core.NETCore, Version=4.13.0.0, Culture=neutral, PublicKeyToken=ca42a1ee8d2e42d3
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Loupe.Core.NETCore.DLL
Assembly Full Name:  Loupe.Extensibility.NETCore, Version=4.13.0.0, Culture=neutral, PublicKeyToken=ca42a1ee8d2e42d3
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Loupe.Extensibility.NETCore.DLL
Assembly Full Name:  TrimbleCloud.Authentication, Version=3.4.0.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/TrimbleCloud.Authentication.DLL
Assembly Full Name:  TrimbleCloud.Authentication.Desktop, Version=3.3.2.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/TrimbleCloud.Authentication.Desktop.DLL
Assembly Full Name:  Trimble.Sdk.Utilities, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Utilities.DLL
Assembly Full Name:  System.Net.Http, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.dll
Assembly Full Name:  TCPAnalyticsSDK, Version=1.1.2.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/TCPAnalyticsSDK.DLL
Assembly Full Name:  System.Runtime.Serialization, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
Assembly Full Name:  System.Numerics, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
Assembly Full Name:  System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
Assembly Full Name:  TrimbleCloud.Common.Logging, Version=3.0.2.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/TrimbleCloud.Common.Logging.DLL
Assembly Full Name:  TrimbleCloud.Common, Version=3.1.0.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/TrimbleCloud.Common.DLL
Assembly Full Name:  System.Security.Cryptography.ProtectedData, Version=7.0.0.1, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/System.Security.Cryptography.ProtectedData.DLL
Assembly Full Name:  System.Security, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Security/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Security.dll
Assembly Full Name:  System.resources, Version=4.0.0.0, Culture=fr, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.resources/v4.0_4.0.0.0_fr_b77a5c561934e089/System.resources.dll
Assembly Full Name:  Microsoft.Extensions.Logging.Abstractions, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Logging.Abstractions.DLL
Assembly Full Name:  Microsoft.Extensions.Logging, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Logging.DLL
Assembly Full Name:  Microsoft.Extensions.Options, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Options.DLL
Assembly Full Name:  DotNetZip, Version=1.16.0.0, Culture=neutral, PublicKeyToken=6583c7c814667745
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/DotNetZip.DLL
Assembly Full Name:  Infragistics4.Win.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.v22.2.DLL
Assembly Full Name:  mscorlib.resources, Version=4.0.0.0, Culture=fr, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_fr_b77a5c561934e089/mscorlib.resources.dll
Assembly Full Name:  Trimble.ExternalService.Core, Version=1.0.5.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.ExternalService.Core.DLL
Assembly Full Name:  Trimble.Vce.DeviceIo, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.DeviceIo.DLL
Assembly Full Name:  Microsoft.Extensions.DependencyInjection.Abstractions, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.DependencyInjection.Abstractions.DLL
Assembly Full Name:  Microsoft.AspNetCore.SignalR.Client.Core, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.SignalR.Client.Core.DLL
Assembly Full Name:  Microsoft.AspNetCore.SignalR.Common, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.SignalR.Common.DLL
Assembly Full Name:  Microsoft.AspNetCore.SignalR.Client, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.SignalR.Client.DLL
Assembly Full Name:  Microsoft.Bcl.AsyncInterfaces, Version=7.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Bcl.AsyncInterfaces.DLL
Assembly Full Name:  WindowsBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
Assembly Full Name:  System.Xaml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
Assembly Full Name:  System.Threading.Tasks.Extensions, Version=4.2.0.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/System.Threading.Tasks.Extensions.DLL
Assembly Full Name:  Microsoft.AspNetCore.Http.Connections.Common, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.Http.Connections.Common.DLL
Assembly Full Name:  Microsoft.AspNetCore.SignalR.Protocols.Json, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.SignalR.Protocols.Json.DLL
Assembly Full Name:  Microsoft.AspNetCore.Connections.Abstractions, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.Connections.Abstractions.DLL
Assembly Full Name:  Microsoft.AspNetCore.Http.Connections.Client, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.Http.Connections.Client.DLL
Assembly Full Name:  Microsoft.Extensions.DependencyInjection, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.DependencyInjection.DLL
Assembly Full Name:  hasp_net_windows, Version=9.0.23489.60001, Culture=neutral, PublicKeyToken=56120be447701319
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/hasp_net_windows.DLL
Assembly Full Name:  System.Text.Encodings.Web, Version=7.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/System.Text.Encodings.Web.DLL
Assembly Full Name:  System.Threading.Channels, Version=7.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/System.Threading.Channels.DLL
Assembly Full Name:  Trimble.Sdk.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Core.DLL
Assembly Full Name:  System.Xml.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
Assembly Full Name:  Microsoft.Extensions.Features, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Features.DLL
Assembly Full Name:  System.IO.Pipelines, Version=7.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/System.IO.Pipelines.DLL
Assembly Full Name:  Infragistics4.Shared.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Shared.v22.2.DLL
Assembly Full Name:  Infragistics4.Win.Misc.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.Misc.v22.2.DLL
Assembly Full Name:  UIAutomationProvider, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
Assembly Full Name:  UIAutomationTypes, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
Assembly Full Name:  Autofac, Version=6.5.0.0, Culture=neutral, PublicKeyToken=17863af14b0044da
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Autofac.DLL
Assembly Full Name:  Accessibility, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Assembly Full Name:  Trimble.Sdk.Geometry, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Geometry.DLL
Assembly Full Name:  Trimble.Vce.Data.Machine, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Machine.DLL
Assembly Full Name:  Trimble.Sdk.SCS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.SCS.DLL
Assembly Full Name:  Trimble.CoreX.CSD, Version=2.91.13.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.CoreX.CSD.DLL
Assembly Full Name:  Trimble.Vce.InjectDependencies, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.InjectDependencies.DLL
Assembly Full Name:  Trimble.Sdk.ConfigurationInterfaces, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.ConfigurationInterfaces.DLL
Assembly Full Name:  Trimble.Sdk.Configuration, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Configuration.DLL
Assembly Full Name:  Trimble.Geodetic.AdaptorLibraryConfiguration, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Geodetic.AdaptorLibraryConfiguration.DLL
Assembly Full Name:  Trimble.Geodetic.OpticalLibraryConfiguration, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Geodetic.OpticalLibraryConfiguration.DLL
Assembly Full Name:  Trimble.Geodetic.LeapSecondsConfiguration, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Geodetic.LeapSecondsConfiguration.DLL
Assembly Full Name:  Trimble.GNSS.SatelliteSystemsConfiguration, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.GNSS.SatelliteSystemsConfiguration.DLL
Assembly Full Name:  Trimble.DefaultLegalDescriptionConfiguration, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.DefaultLegalDescriptionConfiguration.DLL
Assembly Full Name:  Trimble.LandXMLToGenio.ConverterConfiguration, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.LandXMLToGenio.ConverterConfiguration.DLL
Assembly Full Name:  Autofac.Extensions.DependencyInjection, Version=8.0.0.0, Culture=neutral, PublicKeyToken=17863af14b0044da
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Autofac.Extensions.DependencyInjection.DLL
Assembly Full Name:  Loupe.Extensions.Logging, Version=4.13.0.0, Culture=neutral, PublicKeyToken=ca42a1ee8d2e42d3
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Loupe.Extensions.Logging.DLL
Assembly Full Name:  TrimbleGeospatial.ScandataServices.Sdk, Version=1.0.8.2, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/TrimbleGeospatial.ScandataServices.Sdk.DLL
Assembly Full Name:  Microsoft.Extensions.Options.ConfigurationExtensions, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Options.ConfigurationExtensions.DLL
Assembly Full Name:  Microsoft.Extensions.Configuration.Binder, Version=7.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Configuration.Binder.DLL
Assembly Full Name:  Trimble.Sdk.Persistence, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Persistence.DLL
Assembly Full Name:  Trimble.Sdk.Units, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Units.DLL
Assembly Full Name:  Trimble.Sdk.Primitives, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Primitives.DLL
Assembly Full Name:  ReactiveUI, Version=18.3.0.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/ReactiveUI.DLL
Assembly Full Name:  Splat, Version=14.4.0.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Splat.DLL
Assembly Full Name:  System.ComponentModel.Composition, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.Composition/v4.0_4.0.0.0__b77a5c561934e089/System.ComponentModel.Composition.dll
Assembly Full Name:  Trimble.Sdk.Features, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Features.DLL
Assembly Full Name:  Trimble.Sdk.FeatureDefinitions, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.FeatureDefinitions.DLL
Assembly Full Name:  Trimble.Sdk.RawData, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.RawData.DLL
Assembly Full Name:  Trimble.Vce.Data.Import, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Import.DLL
Assembly Full Name:  Trimble.Vce.MobileMapping, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.MobileMapping.DLL
Assembly Full Name:  Microsoft.Practices.Prism.Mvvm, Version=1.1.1.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Practices.Prism.Mvvm.DLL
Assembly Full Name:  System.Runtime, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.dll
Assembly Full Name:  System.Resources.ResourceManager, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Resources.ResourceManager/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Resources.ResourceManager.dll
Assembly Full Name:  System.ObjectModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ObjectModel/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.ObjectModel.dll
Assembly Full Name:  EntityFramework, Version=6.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/EntityFramework.DLL
Assembly Full Name:  log4net, Version=2.0.15.0, Culture=neutral, PublicKeyToken=669e0ddf0bb1aa2a
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/log4net.DLL
Assembly Full Name:  Trimble.Vce.Epm, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Epm.DLL
Assembly Full Name:  Trimble.Sdk.MobileMapping, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.MobileMapping.DLL
Assembly Full Name:  Mxips.NET, Version=2.1.8167.30381, Culture=neutral, PublicKeyToken=e789022f6ecb484d
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Mxips.NET.DLL
Assembly Full Name:  Sde.NET, Version=3.5.1.7836, Culture=neutral, PublicKeyToken=fa7d95db1187f161
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Sde.NET.DLL
Assembly Full Name:  PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
Assembly Full Name:  Trimble.Sdk.Coordinates, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Coordinates.DLL
Assembly Full Name:  TISProcess.Net, Version=3.5.1.7836, Culture=neutral, PublicKeyToken=2afac910f877cde3
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/TISProcess.Net.DLL
Assembly Full Name:  Trimble.Vce.ReportEngine, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ReportEngine.DLL
Assembly Full Name:  Trimble.Vce.ParallelComputer.SharpDX, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ParallelComputer.SharpDX.DLL
Assembly Full Name:  Trimble.Vce.ParallelComputer, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ParallelComputer.DLL
Assembly Full Name:  SharpDX, Version=4.2.0.0, Culture=neutral, PublicKeyToken=b4dcf0f35e5521f1
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/SharpDX.DLL
Assembly Full Name:  Trimble.Vce.UI.Reports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Reports.DLL
Assembly Full Name:  Trimble.Vce.ViewModel, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ViewModel.DLL
Assembly Full Name:  Trimble.Vce.GraphicsEngine2D, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.GraphicsEngine2D.DLL
Assembly Full Name:  Trimble.Vis.PdfImporter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.PdfImporter.DLL
Assembly Full Name:  Trimble.Sdk.Alignment, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Alignment.DLL
Assembly Full Name:  PresentationFramework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
Assembly Full Name:  Trimble.Sdk.UI.Commands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.UI.Commands.DLL
Assembly Full Name:  Trimble.Sdk.Data, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Data.DLL
Assembly Full Name:  Trimble.Sdk.Surface, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Surface.DLL
Assembly Full Name:  Trimble.Vce.Data.REB, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.REB.DLL
Assembly Full Name:  Trimble.Vce.Data.ComputationEngine2, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.ComputationEngine2.DLL
Assembly Full Name:  Trimble.Core.CSDUI.MVP, Version=3.4.0.0, Culture=neutral, PublicKeyToken=012f2610d490fd1a
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Core.CSDUI.MVP.DLL
Assembly Full Name:  Trimble.Core.CSD, Version=2.91.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Core.CSD.DLL
Assembly Full Name:  Trimble.Vce.ConnectedWorkspace, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ConnectedWorkspace.DLL
Assembly Full Name:  Trimble.Vce.Services.Tbc, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Tbc.DLL
Assembly Full Name:  Trimble.Vce.Data.LandXML, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.LandXML.DLL
Assembly Full Name:  Trimble.Vce.UI.Wpf, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Wpf.DLL
Assembly Full Name:  CefSharp, Version=106.0.260.0, Culture=neutral, PublicKeyToken=40c4b6fc221f4138
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/CefSharp.DLL
Assembly Full Name:  ReactiveUI.Wpf, Version=18.3.0.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/ReactiveUI.Wpf.DLL
Assembly Full Name:  Trimble.Vce.UI.ScanningCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ScanningCommands.DLL
Assembly Full Name:  Trimble.Vce.Scanning, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Scanning.DLL
Assembly Full Name:  Trimble.Vce.UI.Hoops, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Hoops.DLL
Assembly Full Name:  Trimble.Vce.FeatureExtraction, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.FeatureExtraction.DLL
Assembly Full Name:  Trimble.eCog.API, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.eCog.API.DLL
Assembly Full Name:  System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
Assembly Full Name:  BellbirdInterfaces, Version=1.1.6680.18676, Culture=neutral, PublicKeyToken=e46c466c63fb6536
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/BellbirdInterfaces.DLL
Assembly Full Name:  Trimble.Vce.Data.UASMaster, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.UASMaster.DLL
Assembly Full Name:  Trimble.Sdk.Construction, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Construction.DLL
Assembly Full Name:  Microsoft.WindowsAPICodePack.Shell, Version=1.1.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.WindowsAPICodePack.Shell.DLL
Assembly Full Name:  Infragistics4.Win.UltraWinTabbedMdi.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinTabbedMdi.v22.2.DLL
Assembly Full Name:  Infragistics4.Win.UltraWinGrid.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinGrid.v22.2.DLL
Assembly Full Name:  System.IO.Compression, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.dll
Assembly Full Name:  Trimble.Sdk.FeatureExtraction, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.FeatureExtraction.DLL
Assembly Full Name:  Trimble.Sdk.Scanning, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Scanning.DLL
Assembly Full Name:  Trimble.Sdk.Results, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Results.DLL
Assembly Full Name:  Trimble.Sdk.Cadastral, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Cadastral.DLL
Assembly Full Name:  Trimble.Sdk.Cadastral.Interfaces, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Cadastral.Interfaces.DLL
Assembly Full Name:  Trimble.Sdk.GNSSData, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.GNSSData.DLL
Assembly Full Name:  Infragistics4.Win.UltraWinTree.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinTree.v22.2.DLL
Assembly Full Name:  Trimble.Vce.UI.Controls.PropertyGrid, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Controls.PropertyGrid.DLL
Assembly Full Name:  Trimble.Sdk.ForeignCad, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.ForeignCad.DLL
Assembly Full Name:  WindowsFormsIntegration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
Assembly Full Name:  Microsoft.Practices.EnterpriseLibrary.Validation, Version=6.0.0.0, Culture=neutral, PublicKeyToken=9d493c709b8014cc
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Practices.EnterpriseLibrary.Validation.DLL
Assembly Full Name:  Microsoft.Practices.EnterpriseLibrary.Common, Version=6.0.0.0, Culture=neutral, PublicKeyToken=9d493c709b8014cc
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Practices.EnterpriseLibrary.Common.DLL
Assembly Full Name:  System.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll
Assembly Full Name:  Infragistics4.Win.UltraWinEditors.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinEditors.v22.2.DLL
Assembly Full Name:  Trimble.Vce.Hoops, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Hoops.DLL
Assembly Full Name:  Trimble.Sdk.GraphicsModel, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.GraphicsModel.DLL
Assembly Full Name:  hoops_mvo2720_cs141, Version=27.20.0.0, Culture=neutral, PublicKeyToken=5719c287a5a3450e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/hoops_mvo2720_cs141.DLL
Assembly Full Name:  hics2720_cs141, Version=27.20.0.0, Culture=neutral, PublicKeyToken=5719c287a5a3450e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/hics2720_cs141.DLL
Assembly Full Name:  hoops_stream2720_cs141, Version=27.20.0.0, Culture=neutral, PublicKeyToken=5719c287a5a3450e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/hoops_stream2720_cs141.DLL
Assembly Full Name:  Trimble.Vce.Services.Construction, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Construction.DLL
Assembly Full Name:  Trimble.Vce.GE.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.GE.Core.DLL
Assembly Full Name:  Trimble.Vce.UI.MonitoringCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.MonitoringCommands.DLL
Assembly Full Name:  Trimble.Vce.Monitoring, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Monitoring.DLL
Assembly Full Name:  Trimble.Sdk.Monitoring, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Monitoring.DLL
Assembly Full Name:  Trimble.Vce.Services.Monitoring, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Monitoring.DLL
Assembly Full Name:  Trimble.Vce.UI.ConstructionCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ConstructionCommands.DLL
Assembly Full Name:  Trimble.Vce.UI.ConstructionReports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ConstructionReports.DLL
Assembly Full Name:  Trimble.Vce.Functions.SCS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Functions.SCS.DLL
Assembly Full Name:  Infragistics4.Win.UltraWinChart.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinChart.v22.2.DLL
Assembly Full Name:  Infragistics4.Win.UltraWinListView.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinListView.v22.2.DLL
Assembly Full Name:  Trimble.Vce.UI.Construction, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Construction.DLL
Assembly Full Name:  Trimble.Vce.Services.Tcc, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Tcc.DLL
Assembly Full Name:  System.Runtime.Caching, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Caching/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.Caching.dll
Assembly Full Name:  NTJV.UI.Commands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/NTJV.UI.Commands.DLL
Assembly Full Name:  NTJV.ViewModel, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/NTJV.ViewModel.DLL
Assembly Full Name:  Trimble.Vce.Data.JobXML, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.JobXML.DLL
Assembly Full Name:  Trimble.Vce.Data.RXL, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.RXL.DLL
Assembly Full Name:  Trimble.Vce.Data.GeneralSurvey, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.GeneralSurvey.DLL
Assembly Full Name:  Microsoft.Win32.Registry, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Win32.Registry.DLL
Assembly Full Name:  Trimble.Vce.Data.GIS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.GIS.DLL
Assembly Full Name:  DataInteroperabilityComponent, Version=1.6.1.7, Culture=neutral, PublicKeyToken=3c2e0c2def562052
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/DataInteroperabilityComponent.DLL
Assembly Full Name:  Trimble.Penmap.IDiagnostics, Version=1.0.0.0, Culture=neutral, PublicKeyToken=dabc04b9c91d084c
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Penmap.IDiagnostics.DLL
Assembly Full Name:  Trimble.Penmap.IFolderProvider, Version=1.0.0.0, Culture=neutral, PublicKeyToken=dabc04b9c91d084c
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Penmap.IFolderProvider.DLL
Assembly Full Name:  Trimble.VCE.Data.IFC, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.IFC.DLL
Assembly Full Name:  IfcExportSDK2.Interop, Version=1.0.8676.11656, Culture=neutral, PublicKeyToken=c468c97453e54754
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/IfcExportSDK2.Interop.DLL
Assembly Full Name:  Trimble.Technology.TrimBim, Version=2.30.0.0, Culture=neutral, PublicKeyToken=93c0f7e4f1ca9619
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Technology.TrimBim.DLL
Assembly Full Name:  Trimble.Vce.Data.ReceiverRaw, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.ReceiverRaw.DLL
Assembly Full Name:  Trimble.Vce.Data.ScJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.ScJob.DLL
Assembly Full Name:  Trimble.Vce.Data.FieldBookJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.FieldBookJob.DLL
Assembly Full Name:  Trimble.Vce.Data.MercuryJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.MercuryJob.DLL
Assembly Full Name:  Trimble.Vce.Data.TDS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.TDS.DLL
Assembly Full Name:  Trimble.Vce.Data.SpJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SpJob.DLL
Assembly Full Name:  Trimble.Vce.Data.TDE, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.TDE.DLL
Assembly Full Name:  Trimble.Vce.Data.NGSDataSheet, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.NGSDataSheet.DLL
Assembly Full Name:  Trimble.Vce.Data.DC, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.DC.DLL
Assembly Full Name:  Trimble.Vce.Data.Custom, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Custom.DLL
Assembly Full Name:  TA_SwigDbMgd, Version=23.9.0.0, Culture=neutral, PublicKeyToken=fbe3dc80c9fe0828
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/TA_SwigDbMgd.DLL
Assembly Full Name:  Trimble.Sdk.SurveyCAD, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.SurveyCAD.DLL
Assembly Full Name:  Trimble.Vce.Data.TTM, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.TTM.DLL
Assembly Full Name:  Trimble.Vce.Data.Moss, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Moss.DLL
Assembly Full Name:  Trimble.Vce.Data.SCSResults, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SCSResults.DLL
Assembly Full Name:  Trimble.SPJLib, Version=1.51.23100.241, Culture=neutral, PublicKeyToken=36d9a2a67ff4b07d
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.SPJLib.DLL
Assembly Full Name:  Trimble.HCC.TBC.Intefaces, Version=1.0.0.0, Culture=neutral, PublicKeyToken=0c98c1339e2d36f4
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.HCC.TBC.Intefaces.DLL
Assembly Full Name:  Trimble.HCC.TBC.NoteLib, Version=1.0.0.0, Culture=neutral, PublicKeyToken=0c98c1339e2d36f4
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.HCC.TBC.NoteLib.DLL
Assembly Full Name:  Trimble.Vce.Data.M5, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.M5.DLL
Assembly Full Name:  Trimble.Vce.Data.OPUSSolution, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.OPUSSolution.DLL
Assembly Full Name:  Trimble.Vce.Data.RTXSolution, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.RTXSolution.DLL
Assembly Full Name:  Trimble.Vce.Data.Zip, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Zip.DLL
Assembly Full Name:  Trimble.Vce.Data.GeoRefImage, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.GeoRefImage.DLL
Assembly Full Name:  Trimble.Vce.Data.KOF, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.KOF.DLL
Assembly Full Name:  Trimble.Vce.Data.SBG, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Sbg.DLL
Assembly Full Name:  Trimble.Vce.ISTRAMimporter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ISTRAMimporter.DLL
Assembly Full Name:  Trimble.Vce.Data.FXL, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.FXL.DLL
Assembly Full Name:  Trimble.Vce.Data.Ashtech, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Ashtech.DLL
Assembly Full Name:  Trimble.Vce.Data.AshtechJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.AshtechJob.DLL
Assembly Full Name:  Trimble.Vce.Data.Skp, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Skp.DLL
Assembly Full Name:  Trimble.Vce.Data.Novapoint, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Novapoint.DLL
Assembly Full Name:  Trimble.Vce.Data.VCL, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.VCL.DLL
Assembly Full Name:  Trimble.Vce.Data.IModel, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.IModel.DLL
Assembly Full Name:  Bentley.DesignSync.Interfaces, Version=1.0.0.0, Culture=neutral, PublicKeyToken=9bfed12b64a9b7df
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Bentley.DesignSync.Interfaces.DLL
Assembly Full Name:  Trimble.Vis.Tools, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.Tools.DLL
Assembly Full Name:  Trimble.Vce.Data.ImageProcessing, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.ImageProcessing.DLL
Assembly Full Name:  Trimble.Vce.Data.PythonImporter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.PythonImporter.DLL
Assembly Full Name:  NTJV.Data.Converter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/NTJV.Data.Converter.DLL
Assembly Full Name:  Trimble.Vce.Data.TXL, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.TXL.DLL
Assembly Full Name:  Trimble.Vce.Data.DJI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.DJI.DLL
Assembly Full Name:  Sitech.Data.D12D, Version=23.1.2149.0, Culture=neutral, PublicKeyToken=ff366c5cb503f093
Assembly Codebase:   file:///C:/Program Files/Sitech Construction Systems/ANZToolbox_23.1/Sitech.Data.D12D.dll
Assembly Full Name:  Sitech.ADAC, Version=0.0.0.0, Culture=neutral, PublicKeyToken=ff366c5cb503f093
Assembly Codebase:   file:///C:/Program Files/Sitech Construction Systems/ANZToolbox_23.1/Sitech.ADAC.dll
Assembly Full Name:  System.ComponentModel.DataAnnotations, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.DataAnnotations/v4.0_4.0.0.0__31bf3856ad364e35/System.ComponentModel.DataAnnotations.dll
Assembly Full Name:  TBCWebApi.Client.Shared, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/TBCWebApi.Client.Shared.DLL
Assembly Full Name:  Trimble.Sdk.PlatformServices, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.PlatformServices.DLL
Assembly Full Name:  Trimble.Vce.GE.Imaging.Gdal, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.GE.Imaging.Gdal.DLL
Assembly Full Name:  Trimble.Vce.Services.Tunneling, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Tunneling.DLL
Assembly Full Name:  Trimble.MonSol.ClientLib, Version=1.12.0.0, Culture=neutral, PublicKeyToken=76a11225be98aa56
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.MonSol.ClientLib.DLL
Assembly Full Name:  Anonymously Hosted DynamicMethods Assembly, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Full Name:  Loupe.Agent.Core.Services, Version=4.13.0.0, Culture=neutral, PublicKeyToken=ca42a1ee8d2e42d3
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Loupe.Agent.Core.Services.DLL
Assembly Full Name:  System.Diagnostics.DiagnosticSource, Version=7.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/System.Diagnostics.DiagnosticSource.DLL
Assembly Full Name:  Sdm.NET, Version=3.5.1.7836, Culture=neutral, PublicKeyToken=fa7d95db1187f161
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Sdm.NET.DLL
Assembly Full Name:  Trimble.Sdk.Core.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.Core.resources.DLL
Assembly Full Name:  Trimble.Sdk.ForeignCad.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.ForeignCad.resources.DLL
Assembly Full Name:  CsdManagementWrapper, Version=3.9.36.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/CsdManagementWrapper.DLL
Assembly Full Name:  GeodeticXWrapper, Version=3.9.36.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/GeodeticXWrapper.DLL
Assembly Full Name:  Trimble.Sdk.Math, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Math.DLL
Assembly Full Name:  Trimble.CoreX.Gdtic, Version=4.60.95.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.CoreX.Gdtic.DLL
Assembly Full Name:  Trimble.Sdk.Coordinates.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.Coordinates.resources.DLL
Assembly Full Name:  Trimble.Sdk.Geodetic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Geodetic.DLL
Assembly Full Name:  Trimble.Sdk.RawData.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.RawData.resources.DLL
Assembly Full Name:  System.Xml.resources, Version=4.0.0.0, Culture=fr, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.resources/v4.0_4.0.0.0_fr_b77a5c561934e089/System.Xml.resources.dll
Assembly Full Name:  Trimble.Sdk.Geodetic.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.Geodetic.resources.DLL
Assembly Full Name:  Trimble.Sdk.Reports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Reports.DLL
Assembly Full Name:  Trimble.Sdk.Data.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.Data.resources.DLL
Assembly Full Name:  Trimble.Sdk.Alignment.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.Alignment.resources.DLL
Assembly Full Name:  Trimble.Sdk.Surface.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.Surface.resources.DLL
Assembly Full Name:  Trimble.Sdk.GNSSData.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.GNSSData.resources.DLL
Assembly Full Name:  Trimble.Sdk.Results.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.Results.resources.DLL
Assembly Full Name:  Trimble.Sdk.Construction.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.Construction.resources.DLL
Assembly Full Name:  Trimble.Sdk.Scanning.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.Scanning.resources.DLL
Assembly Full Name:  Trimble.Sdk.Features.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.Features.resources.DLL
Assembly Full Name:  Trimble.Sdk.MobileMapping.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.MobileMapping.resources.DLL
Assembly Full Name:  Trimble.Sdk.Monitoring.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.Monitoring.resources.DLL
Assembly Full Name:  Trimble.Sdk.FeatureExtraction.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.FeatureExtraction.resources.DLL
Assembly Full Name:  Infragistics4.Win.UltraWinStatusBar.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinStatusBar.v22.2.DLL
Assembly Full Name:  Microsoft.WindowsAPICodePack, Version=1.1.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.WindowsAPICodePack.DLL
Assembly Full Name:  Infragistics4.Win.UltraWinExplorerBar.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinExplorerBar.v22.2.DLL
Assembly Full Name:  System.Windows.Forms.resources, Version=4.0.0.0, Culture=fr, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_fr_b77a5c561934e089/System.Windows.Forms.resources.dll
Assembly Full Name:  Trimble.Vce.UI.Client.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.UI.Client.resources.DLL
Assembly Full Name:  Trimble.Trdm.Contracts, Version=2.20.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Trdm.Contracts.DLL
Assembly Full Name:  SMDiagnostics, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll
Assembly Full Name:  System.ServiceModel.Internals, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Internals/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Internals.dll
Assembly Full Name:  System.ServiceModel.Primitives, Version=4.10.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/System.ServiceModel.Primitives.DLL
Assembly Full Name:  System.IdentityModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IdentityModel/v4.0_4.0.0.0__b77a5c561934e089/System.IdentityModel.dll
Assembly Full Name:  System.ServiceModel.resources, Version=4.0.0.0, Culture=fr, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.resources/v4.0_4.0.0.0_fr_b77a5c561934e089/System.ServiceModel.resources.dll
Assembly Full Name:  SkiaSharp, Version=2.88.0.0, Culture=neutral, PublicKeyToken=0738eb9f132ed756
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/SkiaSharp.DLL
Assembly Full Name:  Trimble.Vce.Share, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.UIManager.dll
Assembly Full Name:  Trimble.Vce.UI.UIManager.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.UI.UIManager.resources.DLL
Assembly Full Name:  Microsoft.ReportViewer.WinForms, Version=15.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.ReportViewer.WinForms.DLL
Assembly Full Name:  Trimble.Vce.UI.PPCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.PPCommands.DLL
Assembly Full Name:  Trimble.Vce.UI.Wrapper, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Wrapper.DLL
Assembly Full Name:  Trimble.Vce.UI.ScsCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ScsCommands.DLL
Assembly Full Name:  Trimble.SCS_WorkOrder, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.SCS_WorkOrder.DLL
Assembly Full Name:  Trimble.Vce.UI.Features, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Features.DLL
Assembly Full Name:  Trimble.Vce.UI.GNSS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.GNSS.DLL
Assembly Full Name:  Trimble.Vce.UI.SCS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.SCS.DLL
Assembly Full Name:  NTJV.UI.CracksControl, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/NTJV.UI.CracksControl.DLL
Assembly Full Name:  Trimble.Vce.UI.Monitoring, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Monitoring.DLL
Assembly Full Name:  Sitech.Commands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=ff366c5cb503f093
Assembly Codebase:   file:///C:/Program Files/Sitech Construction Systems/ANZToolbox_23.1/Sitech.Commands.dll
Assembly Full Name:  Sitech.Common, Version=1.0.0.0, Culture=neutral, PublicKeyToken=ff366c5cb503f093
Assembly Codebase:   file:///C:/Program Files/Sitech Construction Systems/ANZToolbox_23.1/Sitech.Common.DLL
Assembly Full Name:  Trimble.Sdk.UI.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.UI.resources.DLL
Assembly Full Name:  Trimble.Vce.UI.Controls.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.UI.Controls.resources.DLL
Assembly Full Name:  Trimble.Vce.UI.MobileMappingCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.MobileMappingCommands.DLL
Assembly Full Name:  Trimble.ExternalService.API.Client, Version=1.0.5.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.ExternalService.API.Client.DLL
Assembly Full Name:  Trimble.Vce.UI.INetDownload, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.INetDownload.DLL
Assembly Full Name:  IdentityModel.OidcClient, Version=4.0.0.0, Culture=neutral, PublicKeyToken=5580d04c1b6c37c1
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/IdentityModel.OidcClient.DLL
Assembly Full Name:  Trimble.Vce.UI.CoreCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.CoreCommands.DLL
Assembly Full Name:  Trimble.Vis.UI.TccCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.UI.TccCommands.DLL
Assembly Full Name:  Trimble.Vis.UI.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.UI.Core.DLL
Assembly Full Name:  Trimble.Vis.UI.PdfCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.UI.PdfCommands.DLL
Assembly Full Name:  Takeoff.UI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Takeoff.UI.DLL
Assembly Full Name:  Takeoff.Reports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Takeoff.Reports.DLL
Assembly Full Name:  Sitech.Data.D12D.UI, Version=2.0.0.0, Culture=neutral, PublicKeyToken=ff366c5cb503f093
Assembly Codebase:   file:///C:/Program Files/Sitech Construction Systems/ANZToolbox_23.1/Sitech.Data.D12D.UI.dll
Assembly Full Name:  Sitech.UI.ADAC, Version=0.0.0.0, Culture=neutral, PublicKeyToken=ff366c5cb503f093
Assembly Codebase:   file:///C:/Program Files/Sitech Construction Systems/ANZToolbox_23.1/Sitech.UI.ADAC.dll
Assembly Full Name:  Trimble.Sdk.UI.Commands.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.UI.Commands.resources.DLL
Assembly Full Name:  Trimble.Vce.ViewModel.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.ViewModel.resources.DLL
Assembly Full Name:  DynamicData, Version=7.9.0.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/DynamicData.DLL
Assembly Full Name:  Trimble.Vce.MobileMapping.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.MobileMapping.resources.DLL
Assembly Full Name:  Trimble.MonSol.HttpApiClient, Version=1.15.0.0, Culture=neutral, PublicKeyToken=76a11225be98aa56
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.MonSol.HttpApiClient.DLL
Assembly Full Name:  AutoMapper, Version=10.0.0.0, Culture=neutral, PublicKeyToken=be96cd2c38ef1005
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/AutoMapper.DLL
Assembly Full Name:  Trimble.Vce.Services.Tcc.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Services.Tcc.resources.DLL
Assembly Full Name:  Trimble.Vce.Monitoring.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Monitoring.resources.DLL
Assembly Full Name:  Trimble.Vce.Services.Construction.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Services.Construction.resources.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.BaseCommands.dll
Assembly Full Name:  Trimble.Vce.UI.BaseCommands.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.UI.BaseCommands.resources.DLL
Assembly Full Name:  PresentationFramework.Aero2, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll
Assembly Full Name:  PresentationFramework.resources, Version=4.0.0.0, Culture=fr, PublicKeyToken=31bf3856ad364e35
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.resources/v4.0_4.0.0.0_fr_31bf3856ad364e35/PresentationFramework.resources.dll
Assembly Full Name:  System.Windows.Controls.Ribbon, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Controls.Ribbon/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Controls.Ribbon.dll
Assembly Full Name:  Trimble.Vce.UI.Converters, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Converters.DLL
Assembly Full Name:  Microsoft.Scripting, Version=1.3.4.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Scripting.DLL
Assembly Full Name:  IronPython, Version=3.4.1.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/IronPython.DLL
Assembly Full Name:  Microsoft.Dynamic, Version=1.3.4.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Dynamic.DLL
Assembly Full Name:  IronPython.Modules, Version=3.4.1.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/IronPython.Modules.DLL
Assembly Full Name:  Snippets.scripting, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Full Name:  MediatR, Version=9.0.0.0, Culture=neutral, PublicKeyToken=bb9a41a5e8aaa7e2
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/MediatR.DLL
Assembly Full Name:  Trimble.Sdk.Dto, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.Dto.DLL
Assembly Full Name:  Trimble.Sdk.COGO, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.COGO.DLL
Assembly Full Name:  System.ServiceModel.Discovery, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Discovery/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Discovery.dll
Assembly Full Name:  Trimble.Vce.UI.ConstructionCommands.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.UI.ConstructionCommands.resources.DLL
Assembly Full Name:  Trimble.Vce.UI.MobileMappingCommands.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.UI.MobileMappingCommands.resources.DLL
Assembly Full Name:  Trimble.Vce.UI.MonitoringCommands.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.UI.MonitoringCommands.resources.DLL
Assembly Full Name:  Microsoft.Extensions.ObjectPool, Version=2.2.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.ObjectPool.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Takeoff.UI.dll
Assembly Full Name:  Takeoff.UI.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Takeoff.UI.resources.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ConstructionCommands.dll
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.CoreCommands.dll
Assembly Full Name:  Trimble.Vce.UI.CoreCommands.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.UI.CoreCommands.resources.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Features.dll
Assembly Full Name:  Trimble.Vce.UI.Features.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.UI.Features.resources.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.INetDownload.dll
Assembly Full Name:  Trimble.Vce.UI.INetDownload.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.UI.INetDownload.resources.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.MobileMappingCommands.dll
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.PPCommands.dll
Assembly Full Name:  Trimble.Vce.UI.PPCommands.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.UI.PPCommands.resources.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ScanningCommands.dll
Assembly Full Name:  Trimble.Vce.UI.ScanningCommands.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.UI.ScanningCommands.resources.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ScsCommands.dll
Assembly Full Name:  Trimble.Vce.UI.ScsCommands.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.UI.ScsCommands.resources.DLL
Assembly Full Name:  Trimble.Vis.UI.PdfCommands.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vis.UI.PdfCommands.resources.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.UI.TccCommands.dll
Assembly Full Name:  Trimble.Vis.UI.TccCommands.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vis.UI.TccCommands.resources.DLL
Assembly Full Name:  Infragistics4.Win.SupportDialogs.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.SupportDialogs.v22.2.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Client.dll
Assembly Full Name:  Trimble.Vce.Services.WeoGeo, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.WeoGeo.DLL
Assembly Full Name:  Trimble.Vce.Services.Bentley, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Bentley.DLL
Assembly Full Name:  jose-jwt, Version=4.1.0.0, Culture=neutral, PublicKeyToken=e33b67d3bb5581e4
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/jose-jwt.DLL
Assembly Full Name:  System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.Extensions/v4.0_4.0.0.0__31bf3856ad364e35/System.Web.Extensions.dll
Assembly Full Name:  System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
Assembly Full Name:  Trimble.IS.IPPxGate, Version=6.1.0.0, Culture=neutral, PublicKeyToken=62f2fc89c40229e7
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.IS.IPPxGate.DLL
Assembly Full Name:  System.ServiceModel.Channels, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Channels/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Channels.dll
Assembly Full Name:  System.ServiceModel.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Web/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Web.dll
Assembly Full Name:  Infragistics4.Win.UltraWinSchedule.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinSchedule.v22.2.DLL
Assembly Full Name:  PresentationFramework-SystemData, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll
Assembly Full Name:  PresentationFramework-SystemXmlLinq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
Assembly Full Name:  System.IO.Packaging, Version=7.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/System.IO.Packaging.DLL
Assembly Full Name:  Trimble.Sdk.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.resources.DLL
Assembly Full Name:  Trimble.Sdk.Units.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.Units.resources.DLL
Assembly Full Name:  Trimble.Sdk.Interfaces.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.Interfaces.resources.DLL
Assembly Full Name:  WSegmentationManager_x64, Version=0.0.0.0, Culture=neutral, PublicKeyToken=c8536b94f39c562b
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/WSegmentationManager_x64.DLL
Assembly Full Name:  System.Data.DataSetExtensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Data.DataSetExtensions/v4.0_4.0.0.0__b77a5c561934e089/System.Data.DataSetExtensions.dll
Assembly Full Name:  Trimble.Vce.InSphere.Reports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.InSphere.Reports.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ConstructionReports.dll
Assembly Full Name:  Trimble.Vce.UI.ConstructionReports.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.UI.ConstructionReports.resources.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.GNSS.dll
Assembly Full Name:  Trimble.Vce.UI.GNSS.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.UI.GNSS.resources.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Takeoff.Reports.dll
Assembly Full Name:  Takeoff.Reports.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Takeoff.Reports.resources.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Reports.dll
Assembly Full Name:  Trimble.Vce.UI.Reports.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.UI.Reports.resources.DLL
Assembly Full Name:  Trimble.Vce.InSphere.Reports.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.InSphere.Reports.resources.DLL
Assembly Full Name:  hoops2720_cs141, Version=27.20.0.0, Culture=neutral, PublicKeyToken=5719c287a5a3450e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/hoops2720_cs141.DLL
Assembly Full Name:  System.Management, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Assembly Full Name:  Trimble.Vce.GE.Hoops, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.GE.Hoops.DLL
Assembly Full Name:  Trimble.Vce.Hoops.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Hoops.resources.DLL
Assembly Full Name:  Trimble.Vce.UI.Hoops.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.UI.Hoops.resources.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Hoops.dll
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Wrapper.dll
Assembly Full Name:  Trimble.Vce.UI.Wrapper.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.UI.Wrapper.resources.DLL
Assembly Full Name:  Trimble.Vce.UI.Monitoring.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.UI.Monitoring.resources.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Construction.dll
Assembly Full Name:  Trimble.Vce.UI.Construction.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.UI.Construction.resources.DLL
Assembly Full Name:  Infragistics4.Win.UltraWinDataSource.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinDataSource.v22.2.DLL
Assembly Full Name:  Infragistics4.Win.UltraWinTabControl.v22.2, Version=22.2.20222.16, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinTabControl.v22.2.DLL
Assembly Full Name:  Trimble.Vce.UI.Controls.PropertyGrid.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.UI.Controls.PropertyGrid.resources.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Controls.PropertyGrid.dll
Assembly Full Name:  Trimble.WPD.Combined, Version=1.0.0.0, Culture=neutral, PublicKeyToken=e3cd747afe5c1369
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.WPD.Combined.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.DeviceIo.dll
Assembly Full Name:  Trimble.Vce.DeviceIo.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.DeviceIo.resources.DLL
Assembly Full Name:  Trimble.Vce.Data.GeoNav, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Geonav.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Controls.dll
Assembly Full Name:  Trimble.Vce.Compression, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Compression.DLL
Assembly Full Name:  Trimble.Vce.Data.Kml.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Data.Kml.resources.DLL
Assembly Full Name:  PresentationCore.resources, Version=4.0.0.0, Culture=fr, PublicKeyToken=31bf3856ad364e35
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationCore.resources/v4.0_4.0.0.0_fr_31bf3856ad364e35/PresentationCore.resources.dll
Assembly Full Name:  Trimble.Vce.Data.Trajectory, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Trajectory.DLL
Assembly Full Name:  Trimble.Vce.Data.GPSeismic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.GPSeismic.DLL
Assembly Full Name:  Trimble.Vce.Data.Genio, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Genio.DLL
Assembly Full Name:  Trimble.Vce.Data.SDMS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SDMS.DLL
Assembly Full Name:  Trimble.Vce.Data.BlueBook, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Bluebook.DLL
Assembly Full Name:  Trimble.Vce.Data.TMF, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.TMF.DLL
Assembly Full Name:  Trimble.Vce.Data.SenseFly, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SenseFly.DLL
Assembly Full Name:  Sitech.Data.Iredes, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Codebase:   file:///C:/Program Files/Sitech Construction Systems/ANZToolbox_23.1/Sitech.Data.Iredes.dll
Assembly Full Name:  TRBExporter, Version=23.10.104.0, Culture=neutral, PublicKeyToken=d8fd6ae012bed244
Assembly Codebase:   file:///C:/Program Files/SiteVision AR Exporter/SiteVisionExport_23.1/TRBExporter.dll
Assembly Full Name:  Trimble.Vce.Data.DWG.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Data.DWG.resources.DLL
Assembly Full Name:  Trimble.Vce.Data.GIS.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Data.GIS.resources.DLL
Assembly Full Name:  Trimble.Vce.Data.GeneralSurvey.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Data.GeneralSurvey.resources.DLL
Assembly Full Name:  Trimble.Vce.Data.LandXML.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Data.LandXML.resources.DLL
Assembly Full Name:  Trimble.Vce.Data.Machine.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Data.Machine.resources.DLL
Assembly Full Name:  GppProxyEx2013, Version=4.7.10.0, Culture=neutral, PublicKeyToken=26c24350c55da050
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/GppProxyEx2013.DLL
Assembly Full Name:  GppProxy2013, Version=4.7.10.0, Culture=neutral, PublicKeyToken=26c24350c55da050
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/GppProxy2013.DLL
Assembly Full Name:  Trimble.Vce.Data.RXL.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Data.RXL.resources.DLL
Assembly Full Name:  Trimble.Vce.Data.ScJob.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Data.ScJob.resources.DLL
Assembly Full Name:  Trimble.Vce.Data.SDE.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Data.SDE.resources.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SDE.dll
Assembly Full Name:  Trimble.Vce.Data.SpJob.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Data.SpJob.resources.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.TTM.dll
Assembly Full Name:  Trimble.Vce.Data.TTM.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Data.TTM.resources.DLL
Assembly Full Name:  ndrkmiSFZGYH, Version=0.0, Culture=neutral, PublicKeyToken=null
Assembly Full Name:  Trimble.Vce.Data.FXL.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Data.FXL.resources.DLL
Assembly Full Name:  Trimble.Vce.Data.ImageProcessing.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Data.ImageProcessing.resources.DLL
Assembly Full Name:  Trimble.Vce.UI.Wpf.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.UI.Wpf.resources.DLL
Assembly Full Name:  Trimble.Vis.UI.Core.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vis.UI.Core.resources.DLL
Assembly Full Name:  PresentationFramework-SystemXml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
Assembly Full Name:  Windows.UI, Version=255.255.255.255, Culture=neutral, PublicKeyToken=null, ContentType=WindowsRuntime
Assembly Codebase:   file:///C:/WINDOWS/system32/WinMetadata/Windows.UI.winmd
Assembly Full Name:  Windows.Foundation, Version=255.255.255.255, Culture=neutral, PublicKeyToken=null, ContentType=WindowsRuntime
Assembly Codebase:   file:///C:/WINDOWS/system32/WinMetadata/Windows.Foundation.winmd
Assembly Full Name:  System.Runtime.InteropServices.WindowsRuntime, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.InteropServices.WindowsRuntime/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.InteropServices.WindowsRuntime.dll
Assembly Full Name:  System.Runtime.WindowsRuntime, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.WindowsRuntime/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.WindowsRuntime.dll
Assembly Full Name:  TBCWebApi.Client.DataOceanPublisher, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/TBCWebApi.Client.DataOceanPublisher.DLL
Assembly Full Name:  Trimble.Sdk.Properties.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.Properties.resources.DLL
Assembly Full Name:  Trimble.Sdk.Geometry.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.Geometry.resources.DLL
Assembly Full Name:  Trimble.Vce.Data.GNSSProcessor, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.GNSSProcessor.DLL
Assembly Full Name:  Trimble.Vce.Data.ProcessorWrapper, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.ProcessorWrapper.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Hoops.dll
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.ComputationEngine2.dll
Assembly Full Name:  Trimble.Vce.Data.ComputationEngine2.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Data.ComputationEngine2.resources.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.DWG.dll
Assembly Full Name:  Trimble.Vce.Data.GeoRefImage.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Data.GeoRefImage.resources.DLL
Assembly Full Name:  Trimble.VCE.Data.IFC.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.VCE.Data.IFC.resources.DLL
Assembly Full Name:  Trimble.Vce.Data.Skp.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Data.Skp.resources.DLL
Assembly Full Name:  Trimble.Vce.Data.TMF.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Data.TMF.resources.DLL
Assembly Full Name:  Trimble.Sdk.OData, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Sdk.OData.DLL
Assembly Full Name:  Microsoft.GeneratedCode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Full Name:  Microsoft.OData.Client, Version=7.13.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.OData.Client.DLL
Assembly Full Name:  Trimble.Sdk.OData.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Sdk.OData.resources.DLL
Assembly Full Name:  Trimble.Vce.Data.KOF.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Data.KOF.resources.DLL
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.LandXML.dll
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Machine.dll
Assembly Full Name:  Trimble.Vce.Data.SBG.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Data.SBG.resources.DLL
Assembly Full Name:  Trimble.Vce.Data.VCL.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Data.VCL.resources.DLL
Assembly Full Name:  Trimble.Vce.Functions.SCS.resources, Version=1.0.0.0, Culture=fr, PublicKeyToken=551d74244f0db52e
Assembly Codebase:   file:///C:/Program Files/Trimble/Trimble Business Center/fr/Trimble.Vce.Functions.SCS.resources.DLL
Assembly Full Name:  System.Data.SqlXml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Data.SqlXml/v4.0_4.0.0.0__b77a5c561934e089/System.Data.SqlXml.dll
Assembly Full Name:  System.Xml.Xsl.CompiledQuery.1, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Full Name:  System.Xml.Xsl.CompiledQuery.2, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Full Name:  ISymWrapper, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase:   file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/ISymWrapper/v4.0_4.0.0.0__b03f5f7f11d50a3a/ISymWrapper.dll
