I'm attempting to copy and move a set of linestrings that I pulled in from a Siteworks workorder .spj file. Copying appears to work fine, but the copied objects are not able to be moved. Not sure how to resolve
Sie müssen die dazu gehörigen Punkte mit kopieren und verschieben.
um es einfacher zusagen, es lassen sich nur die Punkte verschieben und damit der Linienzug, der Linienzug ist abhängig von seinen Aufnahmepunkten.
must be created by points. if so, you cant move them unless you do a rockpile EXPLODE LINE command. Wish Trimble would let you remove the depend on points from the lines. Just a thought as this is what happens when you create linestring by points inside TBC.
ANZ toolbox has an ‘Unlink’ command that separates lines from points. Not sure if this is restricted to users who buy licence and maintenance through Australian/New Zealand dealer.
Here is a work around. Import the .spj file into TBC, select all the items from the .spj then export it out as a dwg file. Delete the .spj and import in the .dwg and you will have separate items that you can relayer and modify.
good work around idea MT. I have the Rockpile licenses and use the explode line command which removes the point ID references. If, you have the RPS you could also use that command.
