 Utility Nodes Not Showing Up In Sheets
Matthew Judice's profile image
Matthew Judice posted 01-25-2023 13:19
Left is plan and 3d view in TBC, right is what shows up when printing to pdf. For some reason none of the utility boxes are plotted. The pipes show up, as well as the custom blocks I imported for safety end treatments, just not the TBC generated nodes. I can't imagine there's a setting somewhere to disable plotting of utility nodes, what am I missing?
Marian Plucinski's profile image
Marian Plucinski
I do no think that "nodes" will be plotted.
Try to export your utility network via "SiteVision AR Exporter".
It will allow you to create and re-import TRB file. You can Explode or trace TRB outline with a linestring to make it visible on the plot.
