 What happened to the JobXML (.jxl) XML Schema Definitions (.xsd)?
Denon Deterding's profile image
Denon Deterding posted 06-10-2024 18:00
All of the Job file XML Schema Definitions lead to an errored web page:
Service Unavailable
HTTP Error 503. The service is unavailable.
I have tried each of these (there's probably many more hosted from the same server):
http://www.trimble.com/schema/JobXML/5_2/JobXMLSchema-5.2.xsd
http://www.trimble.com/schema/JobXML/6_0/JobXMLSchema-6.02.xsd
http://www.trimble.com/schema/JobXML/6_2/JobXMLSchema-6.20.xsd
http://www.trimble.com/schema/JobXML/6_2/JobXMLSchema-6.21.xsd
http://www.trimble.com/schema/JobXML/6_2/JobXMLSchema-6.22.xsd
http://www.trimble.com/schema/JobXML/6_2/JobXMLSchema-6.27.xsd
Should this be of concern? I would like to review some of the XSDs for programming purposes. Hopefully the JXL file will hang around for a while longer yeah?  Lol
Best,
Denon
Still works for me.
My Edge browser is changing the URL to i.e. "https://ww2.trimble.com/schema/JobXML/6_2/JobXMLSchema-6.27.xsd" though.
Rob Koot's profile image
Rob Koot
Those links work ok for me too. Try http://www.trimble.com/schema/JobXML/6_2/JobXMLSchema-6.27.xsd again. If that works, maybe there had been a temporary outage that we were unaware of.
If that doesn't work, try https://ww2.trimble.com/schema/JobXML/6_2/JobXMLSchema-6.27.xsd. If that doesn't work either, then maybe you need to talk to your IT folk!
While looking at this I noticed 6.29 is missing, I'll look into that. The JXL will not be going away!
