 Why Can't I Create a Negative Side Slope in Corridors?
louis korpela's profile image
louis korpela posted 09-25-2023 13:47
I am trying to create a corridor with surfaces for gravel and asphalt. the asphalt worked just fine but when I go to tie the gravel in with the finished grade using the side slope command, It will not let me do a negative side slope to tie in. I've tried to enter in positive 2 and negative 2 and neither has worked, both result in a positive slope of 2%. At first, I thought this may be a bug in my computer, but we have tried using a couple of computers and no luck. As of right now the closest I can get to a -2 slope is a 0-degree slope. anyone having the same issue?
