Hi Ronny,
Trimble.Vce.UI.Controls.CheckedListBoxEntityPicker is the WinForms control, so it may have some different functionality than the WPF control.
I believe there was a WinForms ListBoxEntityPicker at one time, but maybe it got removed after the CheckedListBoxEntityPicker (with a ShowCheckBoxes property) was created.
I think the WPF and WinForms controls share common code, but their inheritance forks between the two UI technologies (i.e. so you can't "inherit it" from the WinForms side).
I have a dim memory that there was a technical reason why the WPF control doesn't have ShowCheckBoxes...
But maybe it's easier/possible now? (I think Gary is out for a bit, so maybe we can poke
@Charlie Sorg to poke the dev team)
Quan Mueller
Revenant Solutions - TML Development
Sent: 04-26-2022 15:41
Subject: is there a way to disable the Checkboxes in a CheckedListBoxEntityPicker?
I do like the CheckedListBoxEntityPicker and the ability to just set an entity type and searchcontainer.
self.layerticklist.SearchContainer = Project.FixedSerial.LayerContainerself.layerticklist.UseSelectionEngine = Falseself.layerticklist.SetEntityType(clr.GetClrType(Layer), self.currentProject)# Description is the actual property name inside the item in ticklist.Content.Itemssd = System.ComponentModel.SortDescription("Description", System.ComponentModel.ListSortDirection.Ascending)
But I would like to disable the checkboxes in one of my macros. I just need double-click and the highlighted items, which works fine.
The thing is that
Trimble.Vce.UI.Controls.CheckedListBoxEntityPicker does have a property ShowCheckBoxes { get; set; }
but the one that is used in the XAML-Designer
Trimble.Vce.UI.Controls.Wpf.CheckedListBoxEntityPicker does not have this property.
Is there a way to inherit that property?
