In the properties pane for a sheet you can set the Sort-Rank only to values from 0 to 100.
Via macro I can set it to <0 and >100. That works, the properties pane shows those values and the sheets are sorted in the correct order.
What's is the reason for the properties pane being limited to 0-100?
Could my rank setting outside this range lead to any unwanted complications?
Edit: funny Forum error, you can't have <> in the thread subject, I had tried several times with the following subject line "could a Sheet-Sort-Rank <0 and >100 lead to any issues?" and always got an undefined error
