Is anyone else have this issue?
(copied from email notice to dealer)
We are unable to "Publish Field Data to Project Library" since updating to TBC ver. 5.70, specifically the design information (whether a new or existing design results in the same error).
Two different workstation, two different user accounts, two different existing projects, all with the same results shown in the clip below.
What's even more disconcerting is that there is no explanation as to what the error might be so as to try to work around.
I then created a new project, from scratch, called TEMP.
I was able to create the "Job Site" and Project Library folder as expected so the connection to the Project Library is valid and functioning.
I created a simple rectangle and surface at elev 100 in the new project.
I was able to create the GCS/SCS design without issue, however, as you can see below, the Calibration/Control Points/Site Map (all 3 were empty) all published but the simple design would not.
It is imperative that this get fixed immediately. A large amount of high dollar/costly work definitively depends on the proper functionality of the TBC system.
Having to downgrade back to 5.60.2 is not going to be conducive to a happy customer.
Please advise as soon as possible as this is a huge issue that is currently holding up our production.
Thank you,
Richard Tyndall
