Thanks David, I'll play around with the Notification settings.
I finally had some time to go through that documentation and converted my existing 2024 code to the new one. I was surprisingly close with my trial and fail.
To consolidate the info here some sample code on how to create new IFC objects.
The tree in the project explorer is handled by Trimble.Vce.Data.Construction.IFC.BIMEntityCollection, and here you keep adding Trimble.Vce.Data.Construction.IFC.BIMEntity to each other.
bimEntityColl = BIMEntityCollection.ProvideEntityCollection(self.currentProject, True)
bimprojectEntity = bimEntityColl.Add(clr.GetClrType(BIMEntity))
bimprojectEntity.EntityType = "IFCPROJECT"
bimprojectEntity.Description = ifcprojectname # must be set, otherwise export fails
bimprojectEntity.BIMGuid = Guid.NewGuid()
bimobjectEntity = bimprojectEntity.Add(clr.GetClrType(BIMEntity))
bimobjectEntity.EntityType = "IFCBUILDINGELEMENTPROXY"
bimobjectEntity.Description = ifcshellgroupname
bimobjectEntity.BIMGuid = Guid.NewGuid()
bimobjectEntity.Mode = DisplayMode(1 + 64 + 128 + 512 + 4096)
# MUST set layer, otherwise the properties manager will falsly show layer "0"
# but the object is invisible until manually changing the layer
bimobjectEntity.Layer = layer
A mesh object is created/stored in Trimble.Vce.Data.ShellMeshDataCollection
shellMeshDataColl = ShellMeshDataCollection.ProvideShellMeshDataCollection(self.currentProject, True)
shellmeshdata = shellMeshDataColl.AddShellMeshData(self.currentProject)
# ifcnormals = Array[Point3D]([Point3D()]*0)
# don't know why you'd need Normals, since they are defined by the faces and their counter or clockwise definition anyway
shellmeshdata.CreateShellMeshData(ifcvertices, ifcfacelist, ifcnormals)
shellmeshdata.SetVolumeCalculationShell(ifcvertices, ifcfacelist) # unclear if this is necessary
Each mesh has its own serial number. In order to see it on the screen we add a Trimble.Vce.Data.ShellMeshInstance to the appropriate BIMEntity in the tree. This tells that part in the IFC tree to show this specific mesh to be visible at a specific location/transformation.
meshInstance = bimobjectEntity.Add(clr.GetClrType(ShellMeshInstance))
meshInstance.CreateShell(0, shellmeshdata.SerialNumber, Color.Red.ToArgb(), transform)
You can reference the same mesh to multiple BIMEntity with a different transformation each time.
In this example the "transform" is a basic Matrix4D(), since my "ifcvertices" list contains absolute/final coordinates.
The "ifcvertices" is a simple list of Point3D
The "ifcfacelist" is a collection if integers, referencing back to "ifcvertices"
facelist example from a washer object
Sent: 01-23-2025 10:02
Subject: a rare present did popup in the library section - a detailed insight on the IFCMesh class with screenshots and sample code
Thanks for the feedback, Ronny. The best way to stay up-to-date is to enable notifications for new content in each of your communities:
- Click your profile picture in the upper right.
- Select My Account > Community Notifications.
- Scroll down and check the boxes to receive either daily or weekly digests.
You will then get emails when new posts appear.
You are correct that the newly shared files are a bit hidden, but they do appear chronologically on the lower-right side of the home page when you scroll down.
David Kosakowski
