Hello Quan,
having just points in TBC and bulk adding FC's from a CSV is relative unusual. Standard workflow is field work in Access with feature coding in the field and double checking and minor error fixing in the office.
And since TBC is unable to import FC's plus attributes from a CSV file in general, it never was an option anyway. I might actually write one, the biggest issue is the multitude of possible formats of the FC and attribute values.
With a lot of trial and fail, due to Trimble's unwillingness to provide decent documentation, I figured out the following a while ago. Is partly shown in some of my macros.
the FC's with attributes need to be setup/created in TBC beforehand, i.e. via Feature Definition Editor
It all depends on how the FC's are structured in the CSV file.
the following code assumes a CSV-FC string as you'd get when exporting points from TBC (at least exporting is possible)
multiple FC's and attributes; concatenated with "|" into one column and format "FC:Attribute:Value"
not shown as code below is reading the CSV, looping through and processing it line by line, extract FC string from line (basically a csvline.split(",") and sending the correct element/column to the below code)
I'd suggest creating a dictionary from the FC string. Potentially you can create one large dictionary for the whole CSV file that includes the point number as well.
def fcstringtodic(self, fcstring):
fcdic = {}
for fc in fcstring.split("|"):
att = fc.split(":")
if att.Count == 3: # only try to add to dict if we have a "FC:Attribute:Value" combination
if not att[0] in fcdic.keys(): # if the FC doesn't exist in the dict yet add it
fcdic.update({att[0] : {}})
fcdic[att[0]].update({att[1] : att[2]}) # add attribute and value to FC key
return fcdic
you'll have to find the corresponding point, to this specific CSV line, in the TBC database
afterwards you can apply the FC to the point in question and apply the attribute values; the dictionary fcdic in this example always just contains the data for one specific point/line from the CSV
fcdic = self.fcstringtodic(fcstring)
# PointManager doesn't seem to have a fixed serial number; need to find it manually
# seems to be 1040 - but in the SDK it's not explicitly shown as always being this number
for o2 in self.currentProject:
#find PointManager as object
if isinstance(o2, PointManager):
pm = o2
# assuming we have found the "namedPoint" in the TBC data base that we want to apply the current FC from the CSV
for setfc in fcdic: # go through all the keys/FC's of the dictionary; setfc is the feature code abbreviation
pm.SetFeatureCodeAtPoint(namedPoint.SerialNumber, setfc) # set the FC
features = pm.AssociatedRDFeatures(namedPoint.SerialNumber) # retrieve the list of attributes we can try to fill
# try to fill the feature attributes from the dictionary
for f in features:
for attr in f.Definition.AttributeDefinitions:
# lookup values from dictionary - try to find it, that is - no result returns an empty string ""
attrval = fcdic.get(f.Code, {}).get(attr.Name, "")
# set attribute value - weirdly we have to use Add to overwrite it - is not properly documented in the SDK
f.Add(attr.Type, attr.Name, attrval)
Sent: 03-15-2026 15:58
Subject: Adding User Attributes to a Tree point using TML
Hi Ronny,
When I mentioned your macros, I meant for Alan to look through them for sample code on how to assign values to the attributes of point features attached to point objects in TBC.
From Alan's post, it sounded like he wanted to write the macro himself, and was looking for instructions or sample code on how to assign feature attribute values.
More power to you if you want to investigate how to do that yourself - or enhance your own macros - but that's why I tagged @Bryce Haire - he can just look at how TBC sets attribute values (for example via the Properties command) and hopefully provide a few lines of code.
Side note: it sounds like Alan wants a CSV import that adds or updates attribute values in the project - is that an unusual workflow? To update existing point/feature data?
Quan Mueller
Revenant Solutions | TBC Extension Developer
Superuser Program | superuser@revenantsolutions.com
Sent: 03-13-2026 21:37
Hello Alan,
I don't have a macro that does this. This is a rather unusual use case, use point numbers from a project to lookup data in a CSV file and apply the data you find there as attribute values in the project.
My first thought was to export your points as XYZ-CSV, compile a new file with Excels "VLOOKUP", save as CSV and import into TBC.
But, TBC doesn't have an import of CSV data with feature code and attributes. It can't even import the CSV with FC and Attributes it exported itself. Another one of those inexplicably missing features where you wonder why you pay maintenance fees year after year.
Can you send me the CSV and TBC files. Preferably the table with point numbers, station, elevation as well. I need to see how everything is structured, if and how your feature library is set up and how many trees we're talking about. r.schneider.eu@gmail.com
Potentially I can tweak my existing SCR_ImportStaOffEl to create points with FC and Attributes.
