TBC Macros and Extensions
Custom .py macros not appearing in TBC (even minimal test macro)
  • 1.  Custom .py macros not appearing in TBC (even minimal test macro)
    Posted 04-22-2026 19:50
    Hi everyone,
    I'm on TBC 2025.21 with a full Survey Advanced license. No custom macros (including the tiny TestMacro.py below) are appearing in the F12 All Commands pane.
    I have:
    • Placed the .py file(s) directly in C:\ProgramData\Trimble\MacroCommands3\
    • Given "Users" Full Control permissions on the folder
    • Deleted MacroCommands3.dict multiple times
    • Restarted TBC
    • Run "Set Ribbon Tabs → Reset to Defaults"
    AllTerra NZ support also tried the macro on their end and couldn't get it to load either. They suggested posting here.
    Test macro I tried (doesn't appear):
    import clr
    for asm in ['Trimble.Vce.Core']:
        try: clr.AddReference(asm)
        except: pass
    from Trimble.Vce.Core import *
    class TestMacro:
        def __init__(self, project): self.currentProject = project
        def Execute(self):
            print("✅ TEST MACRO RAN SUCCESSFULLY!")
            Client.ShowMessage("Test macro worked!", "Success")
    def CreateCommand(project):
        return TestMacro(project)
    I'm trying to achieve a very simple task: loop through all Total Station observations and write the Azimuth (degrees) and Horizontal Distance as User Attributes on the foresight point.
    Would really appreciate any help. Thanks!
    Mainland Surveying
  • 2.  RE: Custom .py macros not appearing in TBC (even minimal test macro)
    Posted 04-22-2026 22:30
    Edited by Ronny Schneider 04-22-2026 22:45
    Where is your code coming from, is this some "AI" hallucination?
    You didn't supply a command name.
    Here an absolute basic sample, focus on the "Setup" section.
    import clr  # that's an Ironpython module
                # necessary to import .NET assemblies - https://ironpython.net/documentation/dotnet/dotnet.html
                # https://newbedev.com/difference-between-assembly-and-dll
                # "a dll is an assembly, but an assembly may not always be a dll"
    clr.AddReference ('IronPython.Wpf')
    import wpf  # used to load and interpret the XAML user interface
    # not sure why the following 2 don't need the AddReference before importing
    from System.IO import StreamReader  # necessary to load/read the XAML GUI file
    from System.Windows.Controls import StackPanel
    clr.AddReference ("System.Drawing")
    from System.Drawing import Bitmap   # necessary for the icon in the toolbar
    try:
        clr.AddReference ("Trimble.Sdk") # from version 5.50 some assemblies are "pre-referenced" - BUT not all of them
                                         # for some you still have to do it manually
    except:
        clr.AddReference ("Trimble.Vce.Geometry")   # in older versions we have to do it by hand, if the above fails
                                                    # it is TBC < 5.50 and we have to reference manually
    from Trimble.Vce.Geometry import Point3D, Vector3D, Side # now we can load certain classes from the assembly
    def Setup(cmdData, macroFileFolder):
        cmdData.Key = "SCR_T1"
        cmdData.CommandName = "SCR_T1"
        cmdData.Caption = "_SCR_T1"
        cmdData.UIForm = "SCR_T1"      # MUST MATCH NAME FROM CLASS DEFINED BELOW !!!
        cmdData.HelpFile = "Macros.chm"
        cmdData.HelpTopic = "22602"
        try:
            cmdData.DefaultTabKey = "Macro Training"
            cmdData.DefaultTabGroupKey = "Basics"
            cmdData.ShortCaption = "T1 create simple Point-Variable"
            cmdData.DefaultRibbonToolSize = 3 # Default=0, ImageOnly=1, Normal=2, Large=3
            cmdData.Version = 1.00
            cmdData.MacroAuthor = "SCR"
            cmdData.MacroInfo = r""
            cmdData.ToolTipTitle = "T1 create simple Point-Variable - fat Tooltip Title"
            cmdData.ToolTipTextFormatted = "T1 create simple Point-Variable - Tooltip itself"
        except:
            pass
        try:
            b = Bitmap (macroFileFolder + "\\" + cmdData.Key + ".png")
            cmdData.ImageSmall = b
        except:
            pass
    class SCR_T1(StackPanel): # this inherits from the WPF StackPanel control
        def __init__(self, currentProject, macroFileFolder):
            with StreamReader (macroFileFolder + r"\SCR_T1.xaml") as s:
                wpf.LoadComponent (self, s)
            self.currentProject = currentProject
        def OnLoad(self, cmd, buttons, event):
            self.okBtn = buttons[0]
            self.Caption = cmd.Command.Caption
        def OkClicked(self, cmd, e):
            p1 = Point3D(1, 0, 0)
            p2 = Point3D(10, 0, 10)
