There shouldn't be any difference since TBC is creating a temporary JXL from the JOB. Tip of the Week #33 - Easy *.job to *.jxl file conversion (trimble.com)
It still does it in 2023.11. From where you drag your JOB file into TBC you'll see for a split second a JXL popup and disappear.
So, if there is a difference than it is the JXL converter/creator that you used to create the JXL in the first place. Where does the JXL come from, i.e. which Access version?
