How a add GNSS models and antenna models in TBC
  • 1.  How a add GNSS models and antenna models in TBC
    Posted 04-18-2021 22:43
    Hello TBC Team,
    I was wondering is there any way to create customized GNSS model and antenna model in TBC? Our device has been calibrated on NGS but still cannot find in TBC.
    Is there any possible to add models? Thanks for your kindly help in advance:)
    Frank
    Frank Li
  • 2.  RE: How a add GNSS models and antenna models in TBC
    Posted 04-19-2021 17:21
    Hey Frank,
    If you can provide the antenna details I'll push this over to the TBC team to have it added in the next antenna ini file update.
    Regards,
    Shane Lyons
    Shane Lyons
  • 3.  RE: How a add GNSS models and antenna models in TBC
    Posted 04-29-2021 08:42
    Hi Shane,
    is there any way to manually add antenna into the ini file? I found out that in NGS antex files there are calibrations for a long time which are not available in TBC.
    Maybe there is some tool which can convert .atx files into Antenna.ini? or maybe can you share specification of this file as well as .pct or .ngs files?
    thanks,
    Grzegorz
    Grzegorz Nykiel
  • 4.  RE: How a add GNSS models and antenna models in TBC
    Posted 04-29-2021 10:08
    Hey Grzegorz,
    I don't think this is something that Trimble really supports or wants its end users doing for several reasons.
    The proper steps are to submit this to your dealer and we can get the antennas added into the next ini update (usually once a month).
    That being said, I know some advanced users out there that understand the correct coding, etc  and are able to add antennas to be used in TBC. They normally need to make a separate copy of this as once the  update goes through with Trimble it will replace that file (this is why its best to get added through your support portal). I don't think this is something that Trimble supports though.
    I've sent an email to the engineers just to confirm the above and get their thoughts. In the meantime if there is any antennas that you need or want to see added to the file you can send the details and I'll push over to the correct team to get them added in the next update.
    Regards,
    Shane Lyons
    Shane Lyons
  • 5.  RE: How a add GNSS models and antenna models in TBC
    Posted 04-29-2021 15:27
    Thank you Shane for a quick and comprehensive answer. From time to time I have data from some cost-efficient receivers and I have a problem finding antenna models for them. That is where my question came from. This time I have a problem with ESVE600 antenna. Its weird that that Trimble does not convert the whole .atx file to the NGS. There are a lot of calibrations which can be useful for the users. Waiting a month to add it into TBC is a misunderstanding.
    Grzegorz Nykiel
  • 6.  RE: How a add GNSS models and antenna models in TBC
    Posted 04-29-2021 18:36
      |   view attached
    Hello Shane,
    Thanks for your reply. I have attached the antenna information. If more information is needed, I would like to provide. Thank you!
    Regards,
    Frank Li
    Frank Li
    Attachment(s)
    xlsx
    eSurvey GNSS Antenna.xlsx   132 KB 1 version
  • 7.  RE: How a add GNSS models and antenna models in TBC
    Posted 05-10-2025 08:59
    Dear TBC Support Team,
    I am writing to kindly request the addition of the GNSS antenna STXSA1200 (manufacturer: Stonex) to the official antenna database in Trimble Business Center (TBC).
    The official calibration file in ATX format is available at the following link:
    https://geodesy.noaa.gov/ANTCAL/LoadFile?file=STXSA1200_STXR.atx
    Thank you in advance for your support.
    Best regards,
    Edyta Puniach
  • 8.  RE: How a add GNSS models and antenna models in TBC
    Hi Share,
    Best regards,
    Edyta Puniach
    Edyta Puniach
  • 9.  RE: How a add GNSS models and antenna models in TBC
    Posted 05-13-2025 14:38
    Hello
    See the following link, contact whatsApp +51987225205
    https://www.youtube.com/watch?v=Mwg1mOV7QKE
    Juan Brito
    carlosjbritoo@gmail.com
  • 10.  RE: How a add GNSS models and antenna models in TBC
    Posted 07-23-2021 00:24
    Hi Shane,
    Is it possible to have the antenna added in TBC?
    Best regards,
    Frank Li
    Frank Li
  • 11.  RE: How a add GNSS models and antenna models in TBC
    Posted 08-17-2021 05:38
    Edited by Michael Koterba 08-17-2021 05:51
    Frank -  Did you every get your antenna added to TBC?
    Shane -
    I also need an antenna added the Hemisphere631.  Wont let me attach the calibrations, available here https://geodesy.noaa.gov/ANTCAL/    How long will it take to get included?
    Thanks.
    Mike
    Michael Koterba
  • 12.  RE: How a add GNSS models and antenna models in TBC
    Posted 12-16-2021 09:20
    How can you help me to add hitarget v200
    https://geodesy.noaa.gov/ANTCAL/LoadFile?file=HITV200_NONE.atx
    https://geodesy.noaa.gov/ANTCAL/LoadFile?file=HITV200_NONE.003
    pedram tamadon
  • 13.  RE: How a add GNSS models and antenna models in TBC
    Posted 04-14-2025 06:44
    Hi TBC team, I would also like to see Hi-Target V200 added to the list of supported antennas.
    Is there any other way around and not to wait for the update?Any possibility to add .atx file to the correct installation folder and then load it in the TBC directly?
    Thank you for the answer.
    Lukas
    Lukas Agh
  • 14.  RE: How a add GNSS models and antenna models in TBC
    Posted 10-25-2023 07:55
    Hello Shane,
    I would like to ask if it is possible to add support for Emlid's Reach RS2+ GNSS receiver antennas in the Trimble Business Center software. I would be very grateful if you could consider including these antennas in next update.
    Best regards,
    Katarzyna Strząbała
    Katarzyna Strząbała
  • 15.  RE: How a add GNSS models and antenna models in TBC
    Posted 10-26-2023 07:48
    Hi Shane,
    Thank you for your reply.
    The file for this antenna is located on the website to which I posted the link below. I don't know why I can't upload the antenna calibration file.
    Link: Antenna Calibrations (Emlid's Reach RS2+)
    Best regards,
    Katarzyna Strząbała
  • 16.  RE: How a add GNSS models and antenna models in TBC
    Posted 10-27-2023 05:58
    HI Team,
    May I request to add antenna type TWIVC6050, please. We have bundles of this type of antenna arriving for installation within our CORS.
    Many thanks
    Maz
    Mohammad Mazher-ul Choudhury
  • 17.  RE: How a add GNSS models and antenna models in TBC
    Posted 11-20-2023 08:26
    Dear Shane,
    Can you please also add a Satlab Freya antenna?
    https://geodesy.noaa.gov/ANTCAL/LoadFile?file=SLGFREYJA_NONE.atx
    Best Regards
    Kamil Maciuk
  • 18.  RE: How a add GNSS models and antenna models in TBC
    Posted 04-21-2024 08:26
    Hello Shane,
    I recently acquired a TBC license and encountered an issue with Kolida K7 and K30 receivers. Although both models are NGS certified, their antennas are not automatically listed when entering their data.
    I've checked the antenna parameters on the Geodesy NOAA website, and here are the direct links for each model:
    Kolida K7:
    https://geodesy.noaa.gov/ANTCAL/LoadFile?file=KOLK7_NONE.003
    https://geodesy.noaa.gov/ANTCAL/LoadFile?file=KOLK7_NONE.atx
    Kolida K30:
    https://geodesy.noaa.gov/ANTCAL/LoadFile?file=KOLK30_NONE.atx
    https://geodesy.noaa.gov/ANTCAL/LoadFile?file=KOLK30_NONE.003
    Any help would be greatly appreciated.
    Thank you in advance.
    inmofull srl
  • 19.  RE: How a add GNSS models and antenna models in TBC
    Hello  Shane,
    Kolida K7:
    Kolida K30:
    inmofull srl
  • 20.  RE: How a add GNSS models and antenna models in TBC
    Posted 07-08-2024 06:42
    你如何幫助我添加合眾思壯
    https://geodesy.noaa.gov/ANTCAL/LoadFile?file=UNIG970IIPRO_NONE.003
    https://geodesy.noaa.gov/ANTCAL/LoadFile?file=UNIG970IIPRO_NONE.atx
    Shui.Laing Hwang
  • 21.  RE: How a add GNSS models and antenna models in TBC
    Posted 08-08-2024 07:33
    Hello Shane,
    I would like to ask if it is possible to add support for ROLAVI antenna in the Trimble Business Center software. I would be very grateful if you could consider including it in next update.
    https://www.ngs.noaa.gov/ANTCAL/LoadFile?file=RLV0720_NONE.atx
    https://www.ngs.noaa.gov/ANTCAL/LoadFile?file=RLV0720_NONE.003
    Have a nice day.
    Best regards,
    Marco Herrera
    ROLAVI SURVEYOR
  • 22.  RE: How a add GNSS models and antenna models in TBC
    Posted 12-01-2024 05:46
    Hello Shane,
    I would like to ask if it is possible to add support for CHC i93 GNSS receiver antennas in the Trimble Business Center software. I would be very grateful if you could consider including these antennas in next update.
    https://geodesy.noaa.gov/ANTCAL/LoadFile?file=CHCI93_NONE.atx
    https://geodesy.noaa.gov/ANTCAL/LoadFile?file=CHCI93_NONE.003
    Best regards,
    CY TEO
    Chuanyi Teo
  • 23.  RE: How a add GNSS models and antenna models in TBC
    Hello, TBC Team
    I would like to ask if it is possible to add support for CHC i93 antenna in the Trimble Business Center software. I would be very grateful if you could consider including it in next update.
    Have a nice day.
    Best regards,
    CY TEO
    Chuanyi Teo
  • 24.  RE: How a add GNSS models and antenna models in TBC
    Best regards,
    Edyta Puniach
  • 25.  RE: How a add GNSS models and antenna models in TBC
    Posted 05-01-2026 08:48
    Hi Shane,
    I am writing to kindly request the addition of the following GNSS antenna (manufacturer: Ardusimple) to the official antenna database in Trimble Business Center (TBC).
    The official calibration file in ATX format is available at the following links:
    https://geodesy.noaa.gov/ANTCAL/LoadFile?file=AS-ANT2BCAL_NONE.atx
    https://geodesy.noaa.gov/ANTCAL/LoadFile?file=AS-ANT3BCAL_NONE.atx
    https://geodesy.noaa.gov/ANTCAL/LoadFile?file=AS-ANT3BCAL01_NONE.atx
    Best regards,
    Thanassis Mpimis
  • 26.  RE: How a add GNSS models and antenna models in TBC
    Posted 04-16-2025 12:56
    Hello
    Carlos Brito
    Lima-Perú
  • 27.  RE: How a add GNSS models and antenna models in TBC
    I am writing to kindly request the addition of the following GNSS antennas (manufacturer: Ardusimple) to the official antenna database in Trimble Business Center (TBC).
    The official calibration files in ATX format are available at the following links:
    Best regards,
    Thanassis Mpimis
