thanks for that.
Sent: 06-19-2024 11:44
Subject: IFC handling has been changed, again - how to retrieve the triangulated face list?
Hi Ronny,
I've sent in your request for being kept in the loop for IFC development changes during our dev cycle. Hopefully this limits upcoming headaches!
Bryce Haire
Sent: 06-12-2024 17:09
So, I had a look, and it does work as before. You now even have the option which list to retrieve.
0 - The Faces as defined in the IFC, where I have seen faces which were defined of dozens of vertices
1 - the triangulated list, but still with the integer 3 in front of every vertex triplet [3, v1, v2, v3, 3, v1, v2, v3 ...]
2 - the triangulated list but without the 3 and really just the vertex indices [v1, v2, v3, v1, v2, v3 ...]
There is a new enumerator you need to import.
try: # new in 2024.00 from Trimble.Vce.Interfaces import TriangulationContextexcept: pass
A selected IFC object can be made up from several sub-meshes. You'll need to loop through them.
self.ifcType = clr.GetClrType(BIMEntity) for o in self.ifcs.SelectedMembers(self.currentProject): if isinstance(o, self.ifcType): # in case it is an IFC Mesh we get us the coordinates for shellMeshInstance in o.GetGeometry(): shellMeshData = shellMeshInstance.GetShellMeshData() # DEPENDING ON THE TYPE OF IFC THE DIFFERENT METHODS RETURN EMPTY LISTS try: # prior to 2024.00 vertexIndices = shellMeshData.GetTriangulatedFaceList() # this works for the bridge IFC if vertexIndices.Count == 0: vertexIndices = shellMeshData.GetFaces() # this works for the geotech, but not the bridges verticiesLocal = shellMeshData.GetVertex() # verticies as Point3Ds verticiesGlobal = [] for v in range(0, verticiesLocal.Count): verticiesGlobal.Add(shellMeshInstance.GlobalTransformation.TransformPoint(verticiesLocal[v])) except: # new for 2024.00 verticiesGlobal = shellMeshData.GetVertexList(shellMeshInstance.GlobalTransformation) vertexIndices = shellMeshData.GetIndices(TriangulationContext(1)) # triangulationContext 0 - NonTriangulated; 1 - Triangulated; 2 - TriangulatedImplicit without the length entry 3
For my ExplodeIFC macro I prefer to have the vertex indices since I can just throw the start/end integers into a list
linetuples.Add([vertexIndices[t+1], vertexIndices[t+2]])
Once I'm done doing that this list contains probably duplicates, but you can get rid of them very easy with
linetuplesclean = list(set(map(lambda i: tuple(sorted(i)), linetuples)))
That even sorts out lines which are defined the reverse way, i.e. [1,2] and [2,1] are considered the same and just one remains. In that case perfect for what I'm doing and very fast.
Sent: 06-09-2024 20:17
Thanks,
I'll have a look tonight.
Who is Elisha? How do I get onto that mailing list?
Sent: 06-09-2024 19:42
The IShell3DData.GetIndices() method now takes a TriangulationContext parameter.
Elisha sent out an email last December documenting these changes.
https://tbcanz.com/anz-toolbox/
