Thanks for the confirmation.
Currently it's not that dramatic.
I've set the trigger snapmode macro to keyboard shortcut STRG+SHIFT+S. On load it negates the current setting, either restores previous snaps or changes to "Free" only.
And I can hit Escape immediately.
With the help of your other post I can now quickly change between snap/no-snap with just some left-hand key presses. But also keep consistency with the original snap menu.
Sent: 10-07-2024 13:58
Subject: is somebody aware of a way to distinguish if a macro was started via icon or shortcut
Hey Ronny,
I have found no way to reliably determine whether one is fired through 1 mechanism or another (shortcut vs toolbar).
The starting point execution between the shortcut and the ribbon itself is exactly the same.
I think your best approach is to treat them as 2 separate commands unfortunately.
Bryce Haire
