Currently I'm doing it the following way, result is correct, just wondering if there is a one-liner for it.
centerp = o.OriginOfUcs
nv = o.Normal.Clone()
# will only work if Normal != 0, 0, 1
vx = nv.Clone()
# rotate 90 degrees around world-Z axis and make it level with world horizon
vx.RotateAboutZ(math.pi/2)
vx.Horizon = 0
# don't really need vy here - do it anyway
# clone the axis and rotate it 90 degrees around Normal
vy = vx.Clone()
vy.Rotate(BiVector3D(nv, math.pi/2))
# vx, vy and Normal are now square to each other
# compute matrix to line up UCS-X,Z with World-X,Z axis
rottozero = Spinor3D.ComputeRotation(vx, nv, Vector3D(1,0,0), Vector3D(0,0,1))
# transformation to 0, 0, 0
#matrixtozero = Matrix4D.BuildTransformMatrix(Vector3D(centerp), Vector3D(centerp, Point3D(0, 0, 0)), rottozero, Vector3D(1,1,1))
#matrixbackfromzero = Matrix4D.Inverse(matrixtozero)
# transformation without shift - just flatten it
matrixtoflat = Matrix4D.BuildTransformMatrix(Vector3D(centerp), Vector3D(0, 0, 0), rottozero, Vector3D(1,1,1))
matrixbackfromflat = Matrix4D.Inverse(matrixtoflat)
Is there a built-in function to compute the Matrix4D between a Normal vector and World? Edit: between UCS-Normal and World-Z, but keeping UCS-Origin
I've tried,
Plane3D.GetTransformMatrix(o.Normal)
as shown in the ConvertToLinestring sample macro, but the result is wrong.
