Hi Bryce,
really appreciate your quick reply and info !
Just in case anyone else is also struggling with this, we built a workaround for now using instead of:
dateCurrent = License.GetCurrentDate()
which is the one causing the issues now, an own function (dateFromInternet()), however dealing with proxy settings and urllib as we used it also in the past for some of our macros.
dateCurrent = self.dateFromInternet()
which basically requests the current date from the internet from different public date servers i.e.:
res = urlopen('http://just-the-time.appspot.com/', timeout=5)
result = res.read().strip()
result_str = result.decode('utf-8')
And after that, you do whatever needed in your macro with that date, format, etc.
We used several different public servers (i.e. also res = urlopen('http://timeapi.io/api/Time/current/zone?timeZone=etc/utc', timeout=5) ) due to similar issues as the current one with GetCurrentDate() from the internal TBC API, however we still had some macros using the TBC own one and this was our issue now.
Thanks again.
Regards,
Fernando
Fernando Calvo
calvo@calvo-geospatial.com------------------------------
Sent: 01-06-2026 08:15
Subject: License.GetCurrentDate() giving back a false Date (31.12.9999 23:59:59) - Issues with TBC´s public server to check the date over the internet?
This has been found and will be addressed in an upcoming TBC release.
It appears the external sources that we check the datetime from the web have stopped working/migrated and TBC will need a patch to address.
Bryce Haire
