Hi Ronny,
unfortunately I don´t remember where I picked this quote from, but probably from the release notes or from somewhere inside this community, however the information was from Trimble.
I didn´t get it to work and din´t try other ways as I already wasted a lot of time and didn´t want to keep trying if it´s presumably even not possible anyway, for some reason.
Sorry for not being able to help much with this.
Regards,
Fernando
Fernando Calvo
calvo@calvo-geospatial.com------------------------------
Sent: 10-15-2025 16:30
Subject: Macro folder redirection through environment variable does not work ?
Hi Fernando, did you get another folder to work?
Where is that quote from? I did find the environment variable mentioned in the stone old dimensions presentation https://community.trimble.com/HigherLogic/System/DownloadDocumentFile.ashx?DocumentFileKey=40600eca-47da-448a-bff4-9dfebcbaaffa&forceDialog=0 but nowhere else.
Tried it on my private machine with latest V2025.10, doesn't work.
Facing the same issue now with the standard folder being locked during/after install. IT is meanwhile unwilling/unable to remotely login and unlock the folder. Everything needs to be done during the installation via software deployment system, any manual changes afterwards are denied.
