Sent: 07-04-2024 22:37
Subject: MText.TextString method doesnot returns correct text values
Hi Vitalii,
I've found a class TextUtilities in Trimble.Vce.ForeignCad.
That one has some methods to check if the string contains XText formatting or smartcodes, strip those codes and parse the string into a number.
from Trimble.Vce.ForeignCad import TextUtilitiesif not TextUtilities.XTextContainsFormatting(texto.TextString): el1 = TextUtilities.ParseElevationText(texto.TextString, self.currentProject)else: # standard multi-line text is also considered a XText # first strip the codes tt = TextUtilities.GetPlainStringFromXText(texto.TextString, None) # it does accept None; according to the Object Browser it asks for a Trimble.Vce.Graphics.IQueryTextMetrics queryTextMetrics, no idea what that is # parse the remaining string into a number el2 = TextUtilities.ParseElevationText(tt, self.currentProject)
A few years back I've seen texts like 2.335 and the elevation picker failing to recognize the last digit 5. Not sure if that's been fixed meanwhile and how the above-mentioned parser would cope.
Sent: 07-04-2024 12:27
Ronny, thank you for reviewing it.
I believe the best option would be to use the native TBC method "Elevation from text," similar to the one used in WPF's ElevationEdit When clicking on the text. Unfortunately, I couldn't locate it.
You're correct _it looks like_ that .GetSegmentedText Removes the formatting.
It appears that Mtext Can be extensively formatted, and without fully understanding all the formatting rules, regex will likely fail eventually.
Therefore, I've decided to adopt an approach using. .GetTextSegments with a double loop in the function. This seems to be a more reliable method, at least for now. Also, as an option, I probably could explode it or convert it to CADText somehow
@staticmethod def __LabelElevationExtractorDouble(lb): # GetTextSegment instead of.TextString because some of the imported Mtext Returns formatted value for the text like {\C260;14.8} instead of 14.8 try: numbers = [] labelLines = lb.GetTextSegments for line in labelLines: if line.TextString != "": labelText = line.TextString.Trim() pattern = r'\d+(?:\.\d+)?' regex = Regex(pattern, RegexOptions.IgnoreCase) matches = regex.Matches(labelText) for match in matches: numbers.append(float(match.Value)) if len(numbers) != 1: return None return numbers[0] except Exception as err: raise Exception("An error occurred in __LabelElevationExtractorDoubleV2: {}".format(err))
Vitalii Vovk
Sent: 07-04-2024 04:08
Hello Vitalii,
I haven't seen this kind of MText before. But according to this very old forum post it may have something to do with text coloring.
https://forums.autodesk.com/t5/vba/mtext-format-codes/td-p/356713
The method "GetTextSegments" seems to get rid of those codes.
textlines = textobject.GetTextSegments# if your'e sure that's only a one line text your result will be in index 0elevation = textlines[0].TextString# if it's a potential multiline text you'd need to loop trough itfor line in textlines:
With your sample data the GetTextSegments creates a second empty entry in textlines[1]. So, checking the result might need extra code which in fact makes your solution with the Regex stripping maybe the neater one.
There are built-in parse methods like currentProject.Units.Linear.Parse(s) but they require the string to be a proper number from the start, so rather useless for your purpose.
I'll keep digging myself. That's something I was wondering about myself at some point but never had the time to look into it.
