We experience that error daily. Just start using TBC day-in and day-out and it will pop up.
Exception Count: 2
Exception Source: Infragistics4.Win.UltraWinToolbars.v22.2
Exception Type: System.NullReferenceException
Exception Message: Object reference not set to an instance of an object.
Exception Target Site: PositionChildElements
---- Stack Trace ----
Infragistics.Win.UltraWinToolbars.GalleryPreviewItemAreaUIElement.PositionChildElements()
Infragistics4.Win.UltraWinToolbars.v22.2.DLL : N 00405
Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
Infragistics4.Win.v22.2.DLL : N 00161
Infragistics4.Win.v22.2.DLL : N 00343
Infragistics.Win.UIElement.DrawHelper(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Boolean clipText, Boolean forceDrawAsFocused, Boolean preventAlphaBlendGraphics, Nullable`1 zoomFactor)
Infragistics4.Win.v22.2.DLL : N 00555
Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Size elementSize, Boolean preventAlphaBlendGraphics)
Infragistics4.Win.v22.2.DLL : N 00832
Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
Infragistics4.Win.v22.2.DLL : N 00113
Infragistics.Win.UltraControlBase.OnPaint(PaintEventArgs pe)
Infragistics4.Win.v22.2.DLL : N 00237
Infragistics.Win.UltraWinToolbars.UltraToolbarsDockArea.OnPaint(PaintEventArgs pe)
Infragistics4.Win.UltraWinToolbars.v22.2.DLL : N 00146
System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
System.Windows.Forms.dll : N 00102
System.Windows.Forms.Control.WmPaint(Message& m)
System.Windows.Forms.dll : N 00977
System.Windows.Forms.Control.WndProc(Message& m)
System.Windows.Forms.dll : N 00799
System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
System.Windows.Forms.dll : N 00193
Marian
Sent: 05-16-2024 08:36
Subject: Object reference not set to an instance of an object
Hi Fernando,
Are you able to share the specific TDX file that caused an issue for you? Importing a TDX file into a new project did not cause an error on our side.
Thank you!
Virginia Hutchinson
TBC Development Team
Sent: 05-13-2024 06:40
Hi again,
and another one right after I imported a TDX file with some scans onto a new standard project:
(Inner Exception)
Exception Count: 2
Exception Source: Trimble.Sdk
Exception Message: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
Exception Target Site: b
Trimble.Vce.Core.Concordance.b(UInt32 a)
Trimble.Sdk.DLL : N 00037
Trimble.Vce.Core.Components.Project.GetMemberContainer(MandatoryContainers requestedContainer)
Trimble.Sdk.Core.DLL : N 00379
Trimble.Vce.Core.SingleInstanceManager`1.TryGetInstance(InstanceType& instance)
Trimble.Sdk.Core.DLL : N 00220
Trimble.Vce.Core.SingleInstanceManager`1.CreateInstanceAsNeeded()
Trimble.Sdk.Core.DLL : N 00034
Trimble.Vce.Coordinates.CoordinateSystemDefinition.CSDContainer.ProvideCSDContainer(IProject prj)
Trimble.Sdk.Coordinates.DLL : N 00110
Trimble.Vce.UI.Controls.ViewBase.UpdateGridAxis()
Trimble.Vce.UI.Controls.DLL : N 00042
Trimble.Vce.UI.HoopsControls.HoopsPlanView.ProjectSettingsChanged(Boolean needsRegen, Boolean zoomToExtents)
Trimble.Vce.Hoops.DLL : N 00040
Trimble.Sdk.UI.UIEventHandler.Invoke(Object sender, UIEventArgs e)
Trimble.Sdk.UI.DLL : N 00000
Trimble.Vce.UI.UIManager.UIEvents.RaiseProjectSettingsChanged(Object Sender, UIEventArgs e)
Trimble.Vce.UI.UIManager.DLL : N 00053
Trimble.Vce.Coordinates.CoordinateSystemDefinition.CSDContainer.u(CSDefinition a, ICoordinateSystemUI b)
Trimble.Sdk.Coordinates.DLL : N 03762
Trimble.Vce.Coordinates.CoordinateSystemDefinition.CSDContainer.Message(NotificationMessage Msg, Object obj)
Trimble.Sdk.Coordinates.DLL : N 01355
Trimble.Vce.Core.ConcordanceEntry.a(NotificationMessage a, ReasonForCalculate& b)
Trimble.Sdk.DLL : N 00472
Trimble.Vce.Core.ConcordanceEntry.CalculateAsNeeded(EventRaiser a, ReasonForCalculate& b)
Trimble.Sdk.DLL : N 00098
Trimble.Vce.Core.Concordance.a(EventRaiser a, Boolean b, ReasonForCalculate c)
Trimble.Sdk.DLL : N 00295
(Outer Exception)
Exception Count: 2
Exception Type: Trimble.Vce.Interfaces.Client.CalculationException
Exception Message: The entity with serial 1044 threw when sent a NM_Calculate message. [Trimble.Vce.Coordinates.CoordinateSystemDefinition.CSDContainer]
Exception Target Site: a
Trimble.Sdk.DLL : N 01030
Trimble.Vce.Core.Components.a.Calculate(Boolean a, ReasonForCalculate b)
Trimble.Sdk.Core.DLL : N 00588
Trimble.Vce.Core.TransactionManager.s(ReasonForCalculate a)
Trimble.Sdk.DLL : N 00526
Trimble.Vce.Core.TransactionManager.a(CommandGranularity a, String b, String c)
Trimble.Sdk.DLL : N 00092
Trimble.Vce.UI.BaseCommands.ComputeProjectCmd.ComputeProject(Object caller, Boolean addBeginMark, Boolean addSubStepByDefault)
Trimble.Vce.UI.BaseCommands.DLL : N 02365
Trimble.Vce.UI.UIManager.CommandAdapter.Execute(Object parameter)
Trimble.Vce.UI.UIManager.DLL : N 00823
Trimble.Sdk.UI.UiCommandProcessor.c(String a, Boolean b, Boolean c, Object[] d)
Trimble.Sdk.UI.DLL : N 02009
Date and Time: 13.05.2024 15:38:07
Machine Name: XXXXXXXX
IP Address: XXXXXXX
Current User: XXXXXXXXX
Application Domain: TrimbleBusinessCenter.exe
Thread Name: Office UI Thread
---- Assemblies in AppDomain ----
Fernando Calvo
calvo@calvo-geospatial.com
Sent: 05-13-2024 06:24
Hi again Bryce,
I had it again when trying to create a standard new project getting this:
Exception Count: 1
Exception Source: Trimble.Vce.UI.BaseCommands
Exception Message: The object reference was not set to an instance of an object.
Exception Target Site: gzz
Trimble.Vce.UI.BaseCommands.ViewFilters.ViewFilterCmdUI.gzz(IProject a)
Trimble.Vce.UI.BaseCommands.DLL : N 00476
Trimble.Vce.UI.BaseCommands.ViewFilters.ViewFilterCmdUI.ja(IProject a, UIEventArgs b)
Trimble.Vce.UI.BaseCommands.DLL : N 00414
Trimble.Sdk.UI.UIProjectEventHandler.Invoke(IProject Project, UIEventArgs e)
Trimble.Vce.UI.UIManager.UIEvents.RaiseUIProjectLoaded(IProject Project, UIEventArgs e)
Trimble.Vce.UI.BaseCommands.FileNewProjectFromDefaultTemplate.Execute(Object[] Parameters)
Trimble.Vce.UI.BaseCommands.DLL : N 01561
Trimble.Vce.UI.UIManager.DLL : N 00822
Trimble.Sdk.UI.DLL : N 02008
Date and Time: 13.05.2024 15:17:36
Machine Name: XXX-YYYYYYY (name changed)
IP Address: XXX (changed)
Current User: XXX (changed)
Assembly Full Name: mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Assembly Full Name: TrimbleBusinessCenter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TrimbleBusinessCenter.exe
Assembly Full Name: Trimble.Vce.UI.Controls, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Controls.DLL
and many more rows with Assembly Full Name and Assembly Codebase
Does it help?
Thanks.
Regards,
Fernando
Fernando Calvo
Sent: 05-09-2024 09:06
Hi Fernando,
We cannot reproduce this issue locally.
Please attach the steps to reproduce and the team can take a look and see where the issue is coming from.
Thanks!
Bryce Haire
Sent: 05-06-2024 23:07
Hi Marian,
thanks for your feedback. Yes, I have also seen it for a while now on different versions, but not sure since when.
Also still happening with TBac v2023 and 2024.
Can anyone from the TBC development team help please?
Thanks
Fernando
Fernando Calvo
Sent: 05-06-2024 20:59
I've been seeing it since 5.40 ~2020. Still happens in 5.90. Always with chinese character as "target site".
Marian
