TBC Macros and Extensions
there is an unhandled case/bug in Trimble.Vce.Data.GeoRefImage.CreateWorldFile
  • 1.  there is an unhandled case/bug in Trimble.Vce.Data.GeoRefImage.CreateWorldFile
    Posted 13 days ago
    the tool "Create Orthophoto from Pointcloud" or Propeller create Orthophotos with the suffix .tiff, with double f.
    If you pass this filename into CreateWorldFile it fails. If you rename the suffix to .tif, with a single f it works.
    The orthophoto from pointcloud doesn't come with a proper standard wordlfile, that's why I tried to run it through my macro SCR_CreateGeoRefWorldFiles, which failed.
    Until this is fixed, I'll need to work around this with renaming and rerenaming.
  • 2.  RE: there is an unhandled case/bug in Trimble.Vce.Data.GeoRefImage.CreateWorldFile
    Posted 6 days ago
    Hi Ronny,
    CreateWorldFile will be able to process both .tiff and .tif files in the upcoming TBC 2024.00 release.
    Hopefully this will save you some steps!
    Virginia Hutchinson
    TBC Development Team
  • 3.  RE: there is an unhandled case/bug in Trimble.Vce.Data.GeoRefImage.CreateWorldFile
    Posted 6 days ago
    Hello Virginia,
    thanks for the info. For now I have it working, but looking forward to test it once 2024 is out. I'm usually the guinea pig for testing new versions. As long as I know we have nobody even working with 2023.11 yet.
