Hi Dom,
You are correct, TBC is having issues with the permissions on the sub-folder that you created.
If you created the sub-folder directly within MacroCommands3, it will inherit the MacroCommands3 permissions - which don't let you (or TBC running as you) create new files (unless you run TBC as Administrator? maybe that works...)
I would:
- Create a folder on your Desktop (this will have permissions that let you add files/folders to it)
- Drag the folder into MacroCommands3, it will prompt you to sign in as Administrator
If you don't have Administrator rights, you may need help with #2.
Another location (besides your Desktop) is your Temp folder, my path looks like this C:\Users\<myUserName>\AppData\Local\Temp
My extension command installers use this process - they create folders in Temp (creating them as you with your permissions) and then move them into MacroCommands3. Because the installers move folders into MacroCommands3, you have to run them as Administrator (the first time).
Hope that helps, good luck & have fun!
Quan Mueller
Revenant Solutions | TBC Extension Developer
Superuser Program |
superuser@revenantsolutions.com------------------------------
