Thank you for reporting the error, Lubos.
Ronny, I was also able to reproduce the problem in a new project.
The exception will be resolved in the next release, 2024.10. In the meantime, you should be able to create new layer groups without triggering an exception while the View Filter Manager is closed.
Closing and reopening the View Filter Manager will also solve the problem of not seeing new, empty layers.
Virginia Hutchinson
TBC Development Team
Sent: 05-12-2024 12:05
Subject: Trouble with TBc project and need an advice
Thank you for your reply.
I have noticed when I create a new group of layers and new layer, the layer/group can not be seen antill I reopen the layer manager or put some objects in it.
It would be fine to get some adwise from the TBC NASA CENTER :)
Lubos Bejček
Sent: 05-11-2024 17:59
I had a look at your project. With a macro I can create hundreds of layer groups without getting an error.
But as soon as I try to create one with the layer group manager it throws an error. But it only happens once after starting TBC. After throwing the error it doesn't happen again until TBC is restarted.
And the error occurs exactly when layer group 99 is being created. You can try it with an empty project. That implies an error in the layer group manager form implementation.
It's also happening in 2024.00, so something the Trimble guys need to look at.
