Here's an example of how you can use the diagnostics / discovery macro. It's a bit contrived but hopefully you get the idea.
I have legacy data with this field code: SD1. This is a point code for a Shrub, Deciduous with a diameter 1. My current FXL has an SD code with a diameter attribute. I have lots of codes like this, so I want to stick a space between SD and 1 before processing feature codes and then remove the number at the end of the code and insert it as an attribute. However, I only want to do this for Point codes. Line codes like CU1 means a curve with a sequence number.
First, naive implementation with this result from the integration test run...
These aren't actually passes, because I don't have 2773 codes, there's no categorization, valid codes aren't found, etc. The value from this is the realization that I am getting the codes attached to the points, not the codes in the library. Well, how do I access the library? Let's make a diagnostic to explore the API. There's a lot of output so, it goes into a log file in the same directory as your TBC project. Since it's nearly 7,000 lines, we will let the AI chew on it. After a few minutes I get this.
FeatureSettings (Trimble.Vce.Core.Features.FeatureSettings) is the snap-in that holds:
• FxlBasedFeatureDefinitionBlock - the actual FXL library definitions (enumerable)
• FxlFilePath - "BlahBlahBlah.fxl"
• FeatureDefinitionBlock - merged definitions (enumerable)
This is where we should look, not FeatureCodeManager (which gives per-point observations with null types).
Let me add an exploratory integration test that discovers the FXL library API surface, then fix the test assertions. First, let me check existing imports:
After the tests are fixed, we get this
... and after instructing it to update its CLAUDE file, the AI knows everything it needs to about Feature Code Definitions.
David Brubacher
