TBC Tips
By Joseph Blecha posted 01-17-2019 12:33
Here you'll find all TBC Tips linked and accessible for viewing (and re-viewing!):
Use Ctrl+F to search for keywords or Tip #.
Field Data
#4 - Spreadsheets - February 2017
#5 - Process Panorama - March 2017
#18 - Visualizing Survey Data in Google Earth - July 2017
#19 - Investigating Data with Point Derivation Reports - August 2017
#27 - "Sunny" Level Editing - February 2018
#33 - Easy *.job to *.jxl File Conversion - March 2018
#43 - New GNSS Planning Online Tool - June 2018
#62 - Observation Vector Arrows - December 2018
#82 - Lock Leveled Scan Data for Registration and Geo referencing Purposes - August 2019
#101 - Understanding the Session Editor - March 2020
#115 - The Job Converter - July 2020
Adjustment & COGO
#1 - Coordinate Controls - January 2017
#9 - Bearing/Azimuth Angle Controls - May 2017
#22 - Transform Survey Points - January 2018
#29 - Sources of Default Standard Errors - February 2018
#34 - The Power of the Comp Engine and Point Derivation Report - March 2018
#47 - Network Adjustment North/East Components - June 2018
#58 - Average Points vs Merge Points Command - September 2018
#65 - OPUS Alternatives—Post Process Static Data from TBC - January 2019
#150 - Enhanced Baseline Processing with Trimble's RTX Corrections Service - April 2021
#161 - Use the Single Proportioning Command to Re-establish a Corner - October 2021
CAD & Drafting
#2 - Layer Manager - January 2017
#3 - Project Cleanup - February 2017
#6 - Using View Filters - April 2017
#15 - Using the Best-Fit Line Command to Draft Catenary Lines - June 2017
#16 - Using Selection Sets for Time Saving - June 2017
#24 - Label Style Previews - January 2018
#25 - Hiding the Dynaview Frame - January 2018
#32 - Customize Drafting Templates - March 2018
#42 - TBC Point Symbols in AutoCAD - May 2018
#44 - Locking Manual Edits to Feature Coded Geometry - June 2018
#45 - Creating Arcs with Polylines - June 2018
#46 - Ortho Snap Modes - June 2018
#48 - Object Snaps - July 2018
#52 - Creating a Point On-Line Between Two 3D Points - August 2018
#56 - Smart Text in Plan Set Templates - September 2018
#61 - Consistent Drafted Deliverables - November 2018
#76 -  Referencing to Object Attributes and Creating Smart Text - June 2019
#79 - Naming Bounding Geometries using 'Name from Inside Text' - July 2019
#94 - Vector PDF to CAD - December 2019
#96 - Breaking Apart Objects Using the Explode Command - January 2020
#98 - Understanding the Horizontal and Vertical Components of a Linestring - February 2020
#99 - Understanding '?' Line Elevations - February 2020
#122 - Create Fillets & Chamfers with the CAD Command Line - September 2020
#163 - Link a Reference File to a Project - November 2021
#164 - Create a Surface from a Reference File - November 2021
#172 - Right-Click Additions - February 2022
#217 - Drape Geometry Enhancement
#251 - Using Outline Capture
Surfaces & Volumes
#11 - Breakline Tolerances for Surfaces - May 2017
#26 - "Draping" Ortho Images on Surfaces - February 2018
#28 - Staking Cut/Fill Data - February 2018
#39 - Reproject Surface to a New Plane Definition - May 2018
#40 - Offsetting a Surface - May 2018
#41 - Vertical Exaggeration in 3D View - May 2018
#54 - Speed up Surface Volume Calculations - September 2018
#66 - Donut Surfaces (Multiple Surface Boundaries) - January 2019
#87 - Setting maximum edge length to trim surface edges - September 2019
#106 - Flatten Surface Command - May 2020
#110 - Create Surface Intersection Lines - May 2020
#114 - Creating Contour Lines Over a Surface - June 2020
#116 - The Surface Slicer View - July 2020
#121 - The 3D Drive View - August 2020
#123 - The Points to Surface Command - September 2020
#128 - Create a Surface Elevation Grid - October 2020
#132 - The Sample Point Cloud Region Command - December 2020
#195 - Extract Geometry Enhancement [TBC 5.80] - November 2022
#208 - Create a Surface and Surface Info Report - July 2023
#213-Contours Continued
#233: Constraining Surface Meshes with Surface Boundaries
#235: Editing Surfaces with Segment Length Override
#236: Editing Surfaces to Adjust Flat Triangles
Corridors
#10 - Measuring Clearances with SX10 Data - May 2017
#13 - Using the Explore Objects Command - June 2017
#30 - Re-using Road Corridor Templates - March 2018
#53 - Undefined in Corridor Template Instruction - August 2018
#221 - Road Corridors - Visualizing and Quality Control
#229: Save Linework Enhancement to Create Individual Linestrings
Data Prep
#7 - Auto-Advance - April 2017
#8 - Doing Math in TBC - May 2017
#49 - Image Georeferencing - July 2018
#74 - Create Linestring by Station + Offset - May 2019
#93 - Exporting to Sitevision Straight from TBC - December 2019
#178 - Specify As-Staked Point Tolerances - March 2022
#206 - Change Coordinate System - July 2023
Specialty Solutions
Photogrammetry
#12 - Creating Orthorectified Image for Facade Reconstruction - Using Multiple Stations - May 2017
#17 - Quick + Clean Facade Segmentation for Orthophotos - July 2017
#75 - Removing Parallax from Station View - June 2019
#120 - The Capture Image Command - August 2020
#173 - Updated TBC Photogrammetry Ribbon - February 2022
#185 - Determine the Coordinate System of an Aerial Photogrammetry Dataset - May 2022
#203 - Point Cloud Generation from Imagery - June 2023
#228: Orthomosaic from Facades Command
#232: Validate Drone Data with Background Maps
#237: Baseline Processing Reports and the Session Editor
Mobile Mapping
#142 - Mobile Mapping Point Cloud Classification Trick - March 2021
#182 - Go To a Mobile Mapping Station Position - May 2022
#223: Create an IRI Report
#230: Automatic Lane Line Extraction
#231: Shoulder Drop Off Analysis
#234: Ortho Lane Command
#238: Batch Processing Mobile Mapping Data
#242: Creating a Mask for Scan Colorization
#246: Custom Classification Model Tips and Tricks
#247: Inspecting Pavement Condition: Automatic Analysis Mode
#253: Establishing a Connection and Reading Features from GIS
#254: Creating a PCI Schema for an ESRI Feature Service
#255: Writing Features to GIS
Point Clouds
#23 - Maximize your PC's RAM for Improved Point Cloud Rendering - January 2018
#60 - Point Cloud Ambient Shading - October 2018
#63 - Point Cloud by Boundary - December 2018
#71 - See Inside Point Clouds - March 2019
#83 - Scan Registration QA Using Cutting Plane View - August 2019
#85 - Using 'Measure Point' Tool to Identify Scans - August 2019
#92 - More Efficiency with Scan Registration - November 2019
#97 - Creating Scan Stations from Total Station scans - January 2020
#100 - Making CAD Objects and Points Using Virtual DR - March 2020
#107 - Extract Ground or Classify Regions ? - May 2020
#108 - Pole Batch Feature Extraction - May 2020
#109 - TBC or TRW ? Which Software Package Best Suits Your Needs ? - May 2020
#112 - The Keep In/ Keep Out Commands - June 2020
#126 - The Measure Vertical Clearance Command - October 2020
#127 - The Add to Region Command - October 2020
#129 - Setting a Limit Box - October 2020
#132 - The Filter Station Scan Points Command - January 2021
#140 - Batch Import of Point Cloud Files - February 2021
#141 - Extract Classified Interior Point Cloud Regions - February 2021
#154 - How to Extract Multiple Lines at the Same Time - August 2021
Platform
#14 - Customized Keyboard Shortcuts, Ribbons, and the Quick Access Toolbar - June 2017
#20 - Tricks and Right-Clicks - August 2017
#21 - Tips and Zips (Importing a .zip file) - October 2017
#31 - TBC Help is Closer than You Think - March 2018
#35 - Where are all the TBC Report Settings at? - April 2018
#36 - Your New Home Page... - April 2018
#37 - Version Upgrade Eligibility - April 2018
#38 - Available License Servers - April 2018
#50 - Graphic Selection Methods - August 2018
#51 - Quick Zoom Extents - August 2018
#55 - Save Reminders - September 2018
#57 - Context Menu Customization - September 2018
#59 - Freehand (Lasso) Selection - October 2018
#64 - View Filter Manager Shortcuts - January 2019
#67 - Background Map to Verify Data - February 2019
#68 - Dock the Properties - February 2019
#69 - Guided Workflows Directly from TBC Help - March 2019
#70 - Drag and Drop Data Import - March 2019
#72 - Selection Box in Commands - April 2019
#73 - Make Objects Unselectable - April 2019
#76 - Customizing the Ribbon Tabs - June 2019
#80 - Even More Granular Visibility with Selection Sets - July 2019
#81 - How the Geoid Affects Height and Elevation computations - August 2019
#84 - Adding to Layer Using Plan View - August 2019
#86 - Creating Different Viewpoints Using the 'Defined Views' Command - September 2019
#88 - Easy Navigation to Commands Using the 'Command Pane' - September 2019
#89 - Presentation of Your Data Using TBC - October 2019
#90 - Modify Your Selections Using Advanced Select - October 2019
#91 - Help Getting Started with Major Workflows Instructions - November 2019
#95 - Finding Points in the Graphical Views - December 2019
#97 - Expanding Functionality Using TML's - January 2020
#102 - Understanding Coordinate Quality Symbols - March 2020
#103 - Keeping Track of Your Work Using the 'History Log' - April 2020
#104 - Changing the Display Settings of Image Files - April 2020
#105 - Understanding the Different Icons in the Project Explorer - April 2020
#111 - Utilizing the Import Pane - June 2020
#113 - Right Clicking in the Command Pane - June 2020
#117 - Release Notes Shortcut - July 2020
#118 - The Edit Shortcut - August 2020
#119 - Unzipping & Zipping a VCE Package - August 2020
#124 - The Export Feature Attributes Command - September 2020
#125 - Create a 3D PDF - September 2020
#130 - Exporting a Feature Extraction Attribute Map - November 2020
#131 - Disabling a Laptop Integrated Graphics Card - November 2020
#133 - TBC eLearning - December 2020
#134 - TBC Resources PDF Presentation - January 2021
#135 - Importing a Newer VCE File into an Older TBC Version - January 2021
#136 - TBC Sample Datasets - January 2021
#138 - A Surveyor's Glossary - February 2021
#139 - Time-Dependent Transformation Enhancement in TBC v5.40 - February 2021
#143 - TBC Subscription Licensing - March 2021
#144 - The Add Legend Command - March 2021
#145 - Work with GIS Data Sources in TBC - March 2021
#146 - Manage GIS Connections - April 2021
#147 - Download (Get) a GIS Schema & Export it to a FXL File - April 2021
#148 - How to Change the Quality of Multiple Points at Once -April 2021
#149 - Upload (Write) Processed Features to a GIS Data Source - April 2021
#152 - How to Export to Google Earth with User Defined Display Options - May 2021
#158 - Navigating the View: Mouse Controls in TBC - September 2021
#159 - Display Alternate Units for Velocity and Area - September 2021
#160 - Assign Media File to a Point - October 2021
#162 - Change Project Settings (Transparency of Imported PDFs and Point Color) - November 2021
#166 - New User Profile Capabilities - December 2021
#170 - View Spreadsheets - January 2022
#174 - Top Tips to Get Started in TBC - February 2022
#175 - Sort Imported Files by Filename or Import Order - Feburary 2022
#176 - Select Similar Objects - March 2022
#180 - Set the Pick Aperture - April 2022
#181 - Copying Spreadsheets from TBC - April 2022
#184 - Coordinate System Manager Help - May 2022
#188 - Defining & Customizing Command Shortcuts - July 2022
#189 - Updating Trimble Business Center - August 2022
#190 - Visual & Auditory Learning Styles [YouTube & Power Hours] - August 2022
#191 - Integrated Help - August 2022!
#192 - User Profile Manager - September 2022
#193 - Tribe Business Center version 5.80 - October 2022
#196 - Customize Displacement Vectors (monitoring) - January 2023
#197 - Optimize Workflows with TBC Filter Manager - February 2023
#198 - Generating Predefined Reports in TBC - March 2023
#199 - Repeating and replaying previously executed commands in TBC - April 2023
#201 - Create and Edit Feature Definitions - June 2023
#204 - An Introduction to Macros - June 2023
#205 - Keyboard Shortcuts - July 2023
#209 - Feature Extraction Tree - August 2023
#212 - Background Maps
#214 - Terminology and Symbols
#215 - File Types
#217 - Trimble Business Center V.2021.10 Release
#224: Tagging Imported Files to Group Relevant Files
#226: Trimble Business Center v2024.10 Release
#243: Download Features from a GIS Data Source
#249: Configuring your NVIDIA Graphics Card for Optimal use in TBC
2 comments
04-03-2020 13:15
This is great.  Thank you!
09-14-2018 09:45
Mega helpful Joseph, thank you.
